bush model nu-lcd32tv022hd
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    ok,im trying to fix this tv,symptoms are...
    1,tv powers on from stanby to green light
    2,screen backlights come up,and stay on
    3,no picture but sound(running through ps3)on hdmi input
    4,no other symptoms
    tested so far...
    1,power supply outputting proper voltages
    2,caps fine ,and esr tested on psu
    3,immediatley thought t-con board,checked f1 (smd) marked as "k" on 200 ohm setting,tested less than 30 ohm,(0.01),i have found what i think could be another fuse, this is smd also and is marked as "e" but im not sure if this is a fuse?the f1 fuse and the mystery fuse are both white in color,the mystery fuse,on 200 ohm dmm is measuring "1" on my meter,"1" on 2k,20k,but on the 200k setting the reading starts to rise from 0.086 and keeps rising.
    im unable to post up pics as i dont have a decent camera until 2 wks time,any initial thoughts?
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: bush model nu-lcd32tv022hd
    i forgot to add,there are no on screen menu as well as no picture..
    • retiredcaps
      • Apr 2010
      • 9271
      Is there a pcb designation by this chip?
      --- begin sig file ---
      --- end sig file ---
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        there is r608 next to it wether that is for this mystery fuse im not sure,but i initialy thought it was a smd resister,but havent seen a white one with the marking"e"on it,they normally represent a fuse
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          ok tried elektrotania for schematic/service manual but cant seem to find it on there,anyone know other sites i can try?
            Would it happen to be a Megmeet supply? Replace the two 1000u/10V near the top of the supply board for standby, and the 1000u/35V cap which provides inverter power. Use low ESR long life, I used Panasonic FM (standby) and Chemicon KZE (for inverter.)
            If that fails, check inverter... it's pretty tricky to get to from what I remember (I'm glad I didn't need to get to it to repair an LCD37TV016HD.)
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              no,its a 17pw15-8 which if memory serves me right its a vestel ,im swaying away from checking the inverter at the moment, as the backlights work fine no flickering etc,frustrating as i dont have a camera to put pics up grrr,hopefully next week,im goin to recap the output lytics as a matter of course with fc's anyway,it seems the problem is pointing towards t con
                Vestel makes me want to
                Check T-con fuse.
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  Check T-con fuse.
                  t con fuse is fine,on further investigation on the power supply ,it seems to be riddled with dry/cracked joints,even one of the primary side caps legs just wiggled loose and came out,so going to scan the entire rear side of psu and reflow as needed,that will teach me to be lazy!,there arnt any voltage legends on the output conns,so going to have to try and find the schematic for this psu to get the voltages ,il update when finished on psu
                  • mu2
                    • Oct 2009
                    • 217
                    Not sure if this helps but here goes. I'm working on a Visco VSC-32V1 that I think may have the same mainboard. My problems are similar - power supply voltages are exact, backlights come up - but the screen is gray not blue. T-con fuse is fine. Haven't checked for sound since there isn't a menu.
                    The mainboard has a number 200-107-GF371XC-BH Rev. B - manufactured 8-12-2006, this number is located below U11. I checked the esr of the caps and the fixed and adjustable ldo regulators. The adjustable regulators have some odd voltages but if you check the resistor values and plug into the formula they are dead on!. The only odd thing I found so far is that there are two fixed ldo regulators on the right side near the crystal. The lower one is 1.8 vots and it's correct, the upper one is U5 is a AS1117L-33 which should be a 3.3 volt. It is reading 3.8 volts.
                    I don't have one to try but intend to order it.
                    If you have the same board, see what the output of U5 measures.
                    Mike
                      Above poster, do you get any picture at all with colours messed up or just a grey screen?
                      • mu2
                        • Oct 2009
                        • 217
                        Only getting a gray screen.
                        Mike
                        • multimeter
                          • Jan 2011
                          • 739
                          • united kingdom
                          Mike
                          i havent got to the main board yet,just getting through sorting corrections on psu,but yeah will check them out,the 1117 ldo's are very unrealiable,when you measured the adjustable regs did you make sure your + on dmm is on the large tab ?this is the output for a adj reg,i think a suitable part for your reg is the lm1117-3.3,others may enlighten
                          • mu2
                            • Oct 2009
                            • 217
                            Multimeter,
                            I got the Visco tv working again.
                            I replaced two fixed 3.3 volt ldo regulators on the main board - They both measured 3.8 volts. The was a third on the board but it measured fine.
                            I believe these were parts U-5 and U-7. Also replaced the caps in the vicinity of these regulators. Seem to recall them being 47 uf and 100 uf.
                            The other part I replaced - probably the main culprit - was a Nikos L1117DG on the t-con board. Sorry, I didn't write the pcb reference number down before I closed it up. This is an adjustable type ldo regulator.
                            Hope this helps someone.
                            Mike
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                            • jesterace
                              Samsung UE46ES8000 Blown fuse but no other signs of short
                              by jesterace
                              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                              09-11-2024, 03:14 PM
                            • jshhh
                              Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                              by jshhh
                              Hi guys,
                              I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                              How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                              Anybody know how to remove this type of fuse?
                              (The fuse is toward the bottom of the image labeled F2)...
                              06-17-2025, 01:35 AM
                            • Babbar
                              by Babbar
                              04-12-2024, 01:12 AM
                              Surface Mount Fuses Fundamentals Datasheet
                              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                              10-07-2024, 06:07 AM
