LG 42pc1d issues
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: LG 42pc1d issues
    I believe I recall seeing a way to test IPM's for shorts on Coppell's TV repair blog.
    http://blog.coppelltvrepair.com/2011...s-ipm-for.html
    • QuantumCheese
      • Jan 2012
      • 35
      Originally posted by tom66
      Jealous. Only one variac, one bench supply and two scopes .
      Set your probe to 10X and make sure probe is 600V rated. Probe the Z-drive FFC output and check if the waveform is present (set scope to 5V/div, 100ms/div.)
      Flat as a pancake. about 20V dc on it - I think we have a winner here?
        Yep, that's bad.
        Check if there is 5V DC past the SMD fuse and if there is a 15V supply check that. (I can't remember if the Z-sustain has a 15V supply; but the Y-sustain definitely does.) The 15V is generated from the 5V input, I think.
        • brogdan
          • 18
          • Romania
          hello
          i also have a problem with a LG 42PC1D
          it came with blown fuse and shorted hybrid on ysus
          i changed the hybrid and the fuse, all power supply voltages are ok, but still no image.
          do you have any ideea?
          \i saw that on the mainboard(digital) there are some LEDs: L300 is off and L500-503 are on
          • PlasMatt
            LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
            by PlasMatt
            I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
            09-20-2025, 06:50 PM
          • legg
            LG 42PC3 buffer output doesn't follow YSUS
            by legg
            LG42PC3D -UD originally with green lamp but no display or audio.
            Owner says was working, then went 'pop'.
            All 5V caps bulging. replaced.
            All PSU output voltages within spec but -Vy is low on YSUS.
            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
            eventually shorts DG. Replaced all 3 - -Vy now OK.
            Y scan buffer test point does not follow YSUS output below -50V
            Note: This unit seems to expect YSUS output to park at -Vy in between
            drive signal pattern periods. A replacement drive signal board confirms this....
            11-18-2021, 11:49 AM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • SoulFreeze
            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
            by SoulFreeze
            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
            After repairing the above issue, I realized the following remaining problem,
            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
            The computer recognizes headphones are connected and displays a popup in windows
            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
            06-21-2025, 09:53 AM
