Philips 47PFL6704D/F7 - Help finding compatible remote
  • OneOfEm
    • Jan 2011
    • 31
    I've repaired a Philips 47PFL6704D/F7, and it's working, however it looks like there's no way to change the video source without a remote.
    I've tried 4 different "universal" remotes, including one made by Philips, but none of the Philips codes work. I also tried the "learning mode" on all of these remotes with no luck either.
    I keep checking eBay for an old remote, but keep striking out.
    Any suggestions?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Philips 47PFL6704D/F7 - Help finding compatible remote
    If this is like most other Philips TVs, you can step through the channes AND then the inputs by using Channel up and Channel down. Also , remotes are available from these places.
    Google. (This is actually a DirecTV remote).
    eBay.
    PlainBill
    • OneOfEm
      • Jan 2011
      • 31
      Disregard. I found the correct remote model # (242254902349), and there are several on eBay.
      • OneOfEm
        • Jan 2011
        • 31
        Channel up/down never cycles through the inputs. Counter-intuitive.
        Thanks for the response though, Bill!
        • taurtnt
          Help identifying AMCH073 regulator or finding a compatible replacement
          by taurtnt
          I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
          Here’s what I’ve observed:
          • It has a QFN-16 footprint, similar to NB670.
          • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
          • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
          • Pin 8 also seems to be tied to the same GND plane.
          • The chip only says AMCH073, no manufacturer logo or other markings....
          08-24-2025, 03:06 PM
        • Peeripapo
          Finding a compatible USB Thunderbolt 3 port for this Asus g752vt board
          by Peeripapo
          Hi All,
          so I got an Asus g752vt and the USB C (Thunderbolt) port is broken. I need to find a compatible replacement for that.
          Are all USB C conectors the same or do I need to get a specific one for that board. The USB port brand is LOTES and it has the 1546 number on top of it. Where can I Find a similar one ?
          [COLOR=hsl(var(--text-300)/var(--tw-text-opacity))]
          [/COLOR]...
          04-30-2025, 09:37 AM
        • SemDex
          Philips 32PFL3008H/12 Remote doesnt work
          by SemDex
          Hello guys,
          First post here so sorry if ill do any mistakes..
          Got TV for repair, Philips 32PFL3008H/12, Main board VESTEL 17MB95S-1 170912. TV turns on, has image and everything, but there is no response to remote controll. Checked IR receiver - it gave no signal at all. Replaced IR receiver with no luck, still no response to remote, but i got proper waveform when any button is pressed. so far i tried ruling out software - flashed EEPROM / BIOS / NAND, no luck. At this point, when turned on, TV displays message "SHOP MODE", message closes, tv works as intended....
          10-12-2021, 03:07 PM
        • kalauzz
          Philips 47PFL5028K/12 - Remote Control repair help
          by kalauzz
          my remote control for my beloved TV (Philips 47PFL5028K/12) is no more working.
          Codes of the remote should be :
          PHILIPS 996590004895, YKF314-005
          It's blinking endlessy when I insert AAA batteries.
          Checked cap seems ok, the transistor (i think is that) seems good
          IC not checked.
          I thought also to a stuck key.
          I switched cap and seemed to be ok but it restarted blinking endlessy again..
          May the IC fail if battery polarity is inverted? because my son told me he did that ...
          The schematics...
          09-08-2021, 08:26 AM
        • cstout
          DeLonghi AC Remote only accepts 3V
          by cstout
          Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
          The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
          I can't find any schematics...
          06-03-2024, 03:53 PM
