Sony KE-42XS910 Plasma Y-SUS resistor burned out!
  • Westesh
    • Jan 2012
    This has been giving me many problems and I'm hoping someone can shed light on the subject. The TV is a 2003 model year Plasma, when it is powered up the screen displays a green snow like effect with 1mm lines on both the left and right edge. After tearing it down I noticed a small ceramic resistor on the Y-Sustain board was Burned up. I replaced the Y-Sustain board and after powering up, burned the same resistor Could this have something to do with my power supply?? Maybe linked to the X-sustain or ABUS boards? I should also note that there are no other visual signs of damage on the boards, no blown capacitors/resistors/burned circuitry etc... Please help!
    Wes
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • corrize
    Replacing resistor fuse in Sony DV charger
    by corrize
    Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
    So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
    It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
    06-30-2025, 06:59 PM
  • x_orange90_x
    Sony Bravia KD-50X690E blown resistor
    by x_orange90_x
    I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
    The power supply is 715G8413-P01-001-0H2S...
    07-16-2024, 06:53 AM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • MidnightRoller
    Can a resistor lose resistance after hot air?
    by MidnightRoller
    I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
    I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
    02-02-2022, 11:46 PM
