Grundig GU26HDLCD won't power up
+ More Options
Posts
    Re: Grundig GU26HDLCD won't power up
    Originally posted by bbjunkie
    Ah sorry forgot to mention that! I used the cardboard tube method and discovered it wasn't coming from that inductor. It was coming from the 5vsb transformer. The cap seems to have solved the problem though as the PSU is now totally silent.
    Buzzing can be caused by bad capacitors, because it makes the power supply unstable. Glad you fixed it.
    • bbjunkie
      • Dec 2011
      • 301
      Fault is still there, I think i've found another part of it. If I shut it down on dvb-t it wont switch back on properly.
      If I switch from another input to dvb-t the set stops responding and I have to cycle power to get it operational again (then when I turn it on I have to switch it from dvb-t)
      While I have the scope out I decided to check some voltages. There appears to be some ripple on 12v and 24v. difficult to say, probably close to 0.4vdc ripple on 12v and 0.1v on the 24v line
      This is way above the acceptable range right? I'm thinking that the ripple might be causing the dvb-t section to lock up or crash.
      Excuse pic quality, cant get a good one in this light.
      Scope on .2v /div showing the 12v line
        Way too much ripple. There's probably a bad cap on one of the outputs which is destabilising the power supply control loop. The buzzing is a characteristic symptom. You will need to use an ESR meter to find the bugger, but you'll have to remove the important ones to test.
        (Fun fact: With my LG Plasma I had loads of bulged caps. But in circuit only one of them was bad (1.5 ohm ESR!) so I had one on hand and replaced that. The others measured 0.1 ohms (total) which seemed fine. But later, I removed them all. What did I find? Every cap I removed had more than 1 ohm ESR. Most had 2-3 ohms. I'm guessing a combination of other components, and capacitors in parallel, made the ESR read much lower. And that one cap that measured okay, that was on the output of a buck converter, so it was isolated from everything else.)
        • bbjunkie
          • Dec 2011
          • 301
          Ok, thats my work cut out for tomorrow then
          I've just got a call from a friend who has got me a 42" lcd with a cracked screen. Perfect for some spare parts
          • bbjunkie
            • Dec 2011
            • 301
            Got most caps checked OK - C950 was actually a 1000uf 25v but the schematic says it should be 35v. The silkscreen on the board shows a larger outline than the size of the cap, but it is clear that it has never been touched with a soldering iron. It tested 0.08 ohms and 956uF
            Another im unsure about is a 50v 33uF which is testing at 0.45 ohms and 30uF is this ESR acceptable?
            After checking the 6.3v caps while I was there, I realised that I have checked every cap on the board and they are all ok.
            Plugged the tv back in to check ripple again only to find it has gone, so I switched it to DVB-T mode and sure enough, it came on and is working again.
            Perhaps a bad joint? Who knows!
            Cheers
            Jim
              That's quite high. And it should be a 35V one because the power supply has a +/-5% tolerance in most cases, so the output could be as high as 25.2V.
              0.45 ohms is probably okay for a 33uF. They are generally not ESR critical in such a small capacitance.
              Cheers
              Jim
              Possibly. It *is* a Vestel chassis. They are very prone to bad joints.
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • liquidzorch
                Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                by liquidzorch
                Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                10-18-2024, 05:19 PM
              • Mita99
                Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                by Mita99
                Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                04-27-2025, 07:20 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
