Grundig GU26HDLCD won't power up
Re: Grundig GU26HDLCD won't power up
Fault is still there, I think i've found another part of it. If I shut it down on dvb-t it wont switch back on properly.
If I switch from another input to dvb-t the set stops responding and I have to cycle power to get it operational again (then when I turn it on I have to switch it from dvb-t)
While I have the scope out I decided to check some voltages. There appears to be some ripple on 12v and 24v. difficult to say, probably close to 0.4vdc ripple on 12v and 0.1v on the 24v line
This is way above the acceptable range right? I'm thinking that the ripple might be causing the dvb-t section to lock up or crash.
Excuse pic quality, cant get a good one in this light.
Scope on .2v /div showing the 12v lineAttached Filesif you find these attachements useful please consider making a small donation to the site
Way too much ripple. There's probably a bad cap on one of the outputs which is destabilising the power supply control loop. The buzzing is a characteristic symptom. You will need to use an ESR meter to find the bugger, but you'll have to remove the important ones to test.Fault is still there, I think i've found another part of it. If I shut it down on dvb-t it wont switch back on properly.
(Fun fact: With my LG Plasma I had loads of bulged caps. But in circuit only one of them was bad (1.5 ohm ESR!) so I had one on hand and replaced that. The others measured 0.1 ohms (total) which seemed fine. But later, I removed them all. What did I find? Every cap I removed had more than 1 ohm ESR. Most had 2-3 ohms. I'm guessing a combination of other components, and capacitors in parallel, made the ESR read much lower. And that one cap that measured okay, that was on the output of a buck converter, so it was isolated from everything else.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Got most caps checked OK - C950 was actually a 1000uf 25v but the schematic says it should be 35v. The silkscreen on the board shows a larger outline than the size of the cap, but it is clear that it has never been touched with a soldering iron. It tested 0.08 ohms and 956uF
Another im unsure about is a 50v 33uF which is testing at 0.45 ohms and 30uF is this ESR acceptable?
After checking the 6.3v caps while I was there, I realised that I have checked every cap on the board and they are all ok.
Plugged the tv back in to check ripple again only to find it has gone, so I switched it to DVB-T mode and sure enough, it came on and is working again.
Perhaps a bad joint? Who knows!
Cheers
JimComment
That's quite high. And it should be a 35V one because the power supply has a +/-5% tolerance in most cases, so the output could be as high as 25.2V.Got most caps checked OK - C950 was actually a 1000uf 25v but the schematic says it should be 35v. The silkscreen on the board shows a larger outline than the size of the cap, but it is clear that it has never been touched with a soldering iron. It tested 0.08 ohms and 956uF
0.45 ohms is probably okay for a 33uF. They are generally not ESR critical in such a small capacitance.
Possibly. It *is* a Vestel chassis. They are very prone to bad joints.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by liquidzorchHello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
by Mita99Hi,
Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
