I have kind of an odd problem, there is a bright horizontal bar about 4" tall scrolling from top to bottom, the rest of the image is kind of dark, and slightly mirrored when the bar rolls over it. It's almost like an old CRT with no vertical hold, I will post a video of the problem in about an hour, unless someone helps me out before then!
Sony 46" LCD KDL-46V21L1 - Scrolling bright bar, slight mirrored picture
Re: Sony 46" LCD KDL-46V21L1 - Scrolling bright bar, slight mirrored picture
Ignore my original post, a lot of information is invalid and I need to wait 90 minutes before I can edit it.
UPDATE! Here's a video of the problem until I can edit my original post: http://www.youtube.com/watch?v=lo9oaxxRwVcLast edited by tripslipfall; 12-31-2011, 12:58 AM. -
Alright, so after being on for about an hour, boom, the pictured cleared up perfectly, about a minute later it went back to being messed up, then it went to perfect again, and now it's messed up... Smacking it doesn't seem to do anything.Comment
Does this happen on all inputs? I'd tend to think it's a problem in the scalar area of the main board.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
All inputs, and the menu and OSD is affected as well, but, last night, I left it on for about an hour, it cleared up for a minute, then went back to being screwed again, then I turned it off for a few, turned it back on, and it's been working flawlessly since. Smacking it doesn't change anything, it's still working, it's been turned on and off many times since then. Not sure what's going on, but I'll report back if it gets screwy again.Comment
by mrsithHi, me again.
Grabbed that Sony with 6 blinking lights. Easy job, especially that I had LED set. Replaced them, upon reinstalling everything and doing test I was shocked. The picture is upside down and mirrored. There is some fading effect on one side (4th TV in a row with backlight problem that turned out to have this issue as well...), and there are 2 black vertical bars. Touching side and bottom tabs doesn't produce any change at all.
The LEDs were taken from kdl-x857c, basicay same model. I transferred screen to its chassis to save time, but just in case of any incompatibility... -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...09-06-2024, 05:30 AM
- Loading...
