Sharp Aquos 32"
  • rigeback
    • Mar 2011
    • 421
    • Malta
    #41
    Re: Sharp Aquos 32"
    Well took the back off again to check the lamps with power on and all are working fine, could catch a suntan with lamps like these. No, the problem lies within the power supplies to the t-con etc and I need to fined which LDO or cap is not working??
    • rigeback
      • Mar 2011
      • 421
      • Malta
      #42
      Re: Sharp Aquos 32"
      I have downloaded the specs for the main sharp LDO's to gather information concerning the actual voltage out put, however accordingly this is controlled by the capacity of the in line caps so I am still not sure what to expect, any info much appreciated.
      • rigeback
        • Mar 2011
        • 421
        • Malta
        #43
        Re: Sharp Aquos 32"
        Originally posted by momaka
        I haven't looked at the service manual yet, but I think tom66 has the right idea to check the rest of the voltage regulators. I see a few more.
        Starting with this picture, check IC2303 (left-middle side of the picture, close to the 2 electrolytic capacitors):
        https://www.badcaps.net/forum/attach...6&d=1324947839
        On this picture measure voltage on the pins of IC4202:
        https://www.badcaps.net/forum/attach...3&d=1324944651
        I wonder what the 8-pin ICs with v5805 do. Check voltages on all pins and post back. I wonder if these could be 5v linear regulators.
        https://www.badcaps.net/forum/attach...4&d=1324944651
        Measure voltage on IC1755 and check the 2 fuses to the left of it.
        https://www.badcaps.net/forum/attach...5&d=1324944651
        Lastly, measure voltage on the pins of the IC between the antenna input jack and the card slot. The IC is right below electrolytic capacitor C4420. There's also a 3.3v test point to the right of C4420. Check if that test point gets 3.3v.
        https://www.badcaps.net/forum/attach...2&d=1324333526
        Mr. Momaka please swing by when you have a chance regarding the results for the above, thanks in advance and happy new year.
        • rigeback
          • Mar 2011
          • 421
          • Malta
          #44
          Re: Sharp Aquos 32"
          Well guys you're gonna think I'm banana's but the power has come back again to the t-con and all test points. I decided to re test the t-con without connecting the screen ribbons and manual control board and things are normal again, could be this be a duff screen or control switch??
          Will connect and re test each component next!
            master hoarder
            • May 2008
            • 12170
            #45
            Re: Sharp Aquos 32"
            Maybe, but I doubt it.
            Yes, do that and see if the voltages disappear again.
            Pin 1 is the input to the regulator. This is the voltage that the regulator "uses" to "make" a new voltage.
            Pin 2 is the ON/OFF switch - this is what controls whether the regulator should be working or not. The data sheets you posted for the 2 regulators both state that they (the PQ20WZ** and PQ070XNA1ZPH) will turn on only when the voltage on Pin 2 is above 2.0V.
            Pin 3 is the output for these regulators. The regulator "takes" the voltage from pin 1 and converts it into a lower voltage. The output voltage on this pin depends on the voltage at pin 4.
            Pin 4 - controls what the voltage on pin 3 is.
            Pin 5. Ground (0 volts).
            It may be possible to check if the regulator in question is outputting the correct voltage by measuring resistance between pin 4 and pin 3 as well as between pin 4 and pin 5. Both data sheets state that the output voltage, Vo can be found by the formula:
            Vo = Vref * (1 + R2/R1)
            Vref = 2.64V for the PQ20WZ** regulator and 1.23V for the PQ070XNA1ZPH regulator
            R2 is the resistance between pin 3 and pin 4.
            R1 is the resistance between pin 4 and pin 5.
            This test my not be very accurate, but it should give you a good idea if the regulator is outputting the correct voltage.
            I still haven't sat down and looked through the schematics, but I'll try to do that soon if I can.
              master hoarder
              • May 2008
              • 12170
              #46
              Re: Sharp Aquos 32"
              Aaaand I just went through all of the schematics... whew.
              There's so many things to check I don't even know where to start. It seems this TV uses at least a billion voltage regulators.
              Since there's so many of them, I suggest you cycle the power to the TV every now and then, as in every 5 minutes. The reason for this is to prevent the TV from entering standby after a certain time (if it even does that). Ideally, it would be best to cycle the power before testing each regulator, but that's way too many cycles and is bad for the PSU, so cycling power every 5 minutes should be okay I think.
              Also, disregard my post above about the voltage regulators. Segments 003, 004, and 005 of the schematics you uploaded in post #28 tell you all of the voltages that should be present on each voltage regulator.
              Before you begin, take a note of how the schematics are drawn. Note that all of the power rails are drawn with thicker lines - these are the only rails we are interested in right now. Also, for most regulators, the output pin is denoted with Vo, the input as Vin, and ground as GND. On some of the regulators, like IC1702, IC1735, and IC1745, the output is denoted with SW, however you cannot measure the voltage on that pin since it is SWitched (i.e. pulsed DC). For these you measure at the output capacitors... I will tell you on which capacitors to measure.
              I think the best place to start is page 1 of schematic Segment 005 since it has most of the voltage regulators. You will check the voltage on each and make sure it's good. I compiled a list of all of the voltage rails and which IC/voltage regulator is responsible for these rails:
              B+3.3V --- IC1745 (for this one, measure the output voltage at capacitor C1745 or C1746, otherwise you may get erroneous results)
              BU+5V --- none. BU+5V seems to come from BU5V (pin 11 of connector P1701) through two 1-Ohm resistors in parallel (resistors R1712 and R1711). Check to see if the resistance of these resistors is good. Should be under 3 Ohms, depending on how low your multimeter can measure.
              B+ANT5V --- IC1725
              S+8V --- IC1726
              BU+3.3V --- IC1701
              B+5V --- IC1735 (for this one, measure the output voltage at capacitor C1735 or C1736, otherwise you may get erroneous results)
              B+1.8V --- IC1756
              B+1.2V --- IC1755
              BU+1.8V --- IC1702 (for this one, measure the output voltage at capacitor C1706 or C1707, otherwise you might get erroneous results)
              Next, look on page 8 of schematic Segment 003, lower left corner. The following ICs should have the following voltages:
              IC202: Pin 4 (Vin) = 5V, Pin 5 (Vo) = 3.3V
              IC204: PIN 1 (Vin) = 3.3V, Pin 5 (Vo) = 2.5V
              IC205: PIN 1 (VDD) = 2.5V, Pin 5 (Vo) = 1.0V
              After this, look on page 4 of schematic Segment 004, lower right corner. IC4202 produces the B+2.5V_ST rail (a 2.5v standby rail - should be there whenever the TV is plugged in). Measure voltage on the following pins of IC4202: Pin 1 (Vin) = 3.3V, Pin 3 (Vo) = 2.5V
              Finally, move to Page 5 of schematic Segment 004.
              IC4410: Pin 6 (IN) = 5V, Pin 1 (Out) = 5V (only if Pin 3 (EN) is higher than 1.8V). IC4410 is not actually a regulator but a switch.
              And that's all the regulators I saw so far. Also check VLS15.6V, VGH35V, and VGL-6V again. Let me know if any of the voltges are missing or way out of spec. Out of spec would be +/-5% of the stated voltage value.
              • rigeback
                • Mar 2011
                • 421
                • Malta
                #47
                Re: Sharp Aquos 32"
                One thing I can confirm is when I connect the screen ribbons I loose power to the t-con area VLS15.6V, VGH35V, and VGL-6V.
                I have removed the ribbon connectors for the tests since some of the parts are located on under side of the board.
                • rigeback
                  • Mar 2011
                  • 421
                  • Malta
                  #48
                  Re: Sharp Aquos 32"
                  Hi Momaka, most of the checks went well although I could not find C1706 or C1707, seems they forgot to print the board or I need new eyes or specks! the attached photo illustrates what I believe is the location.
                  IC4202: Pin 1 (Vin) = 3.21V, Pin 3 (Vo) = 0.0V I think it has a problem
                  Finally, move to Page 5 of schematic Segment 004. IC4410: Pin 6 (IN) = 5V, Pin 1 (Out) = 5V (only if Pin 3 (EN) is higher than 1.8V). IC4410 is not actually a regulator but a switch.
                  Here again IC4410: Pin 6 (IN) = 5V, Pin 1 (Out) = 0.00V Pin #3 also 0.0V
                  Bear in mind that the screen connectors were disconnected for all the above since the board had to be rotated anyway.
                    master hoarder
                    • May 2008
                    • 12170
                    #49
                    Re: Sharp Aquos 32"
                    Looks correct to me.
                    Yes, that's a problem. Check voltage om pin 2 (SW) and pin 4 (Vref) of IC4202
                    That one is fine. If the voltage on pin 3 (EN) is less than 1.8V, them the voltage on pin 1 (out) will also be 0V.
                    • rigeback
                      • Mar 2011
                      • 421
                      • Malta
                      #50
                      Re: Sharp Aquos 32"
                      I must have miss probed this one as its okay today Pin 1 (Vin) = 3.21V, Pin 3 (Vo) = 2.45V pin 2 = 3.20V and pin 4 = 1.22V.
                      I re tested every thing and I found some lower values on VGH35V = 30.2V and also on the 2 fuses Next to IC1755 are 3.20V-2.80V both fuses same values across?
                      B+ANT5V --- IC1725
                      And finally IC1725 = on pin 6 is 7.56v and the rest are 0.0 Volts??
                      Thanks for all the help.
                        master hoarder
                        • May 2008
                        • 12170
                        #51
                        Re: Sharp Aquos 32"
                        Not sure about this one. Let's leave it for after we check the other items.
                        They are both in parallel so you should get the same voltage on all pins of these fuses.
                        Better yet, just check the voltage on pin 1 and pin 3 of IC1755. If pin 1 is 3.3V or close and pin 3 (the top tab) is 1.2V, then everything is OK with that rail.
                        There should be 5V on pin 4 - but that's only if there is 1.8V or more on pin 1. Since pin 1 is 0V, then pin 4 is also disabled. I'm not sure if this is normal or not, though. I *think* the TV should turn ON this voltage regulator when it turns ON, but again, that's just a guess. Perhaps it turns ON only when the TV is OFF? I guess you should check that - turn OFF the TV and see if you get 5v on pin 4 of IC1725.
                        If not, we might have a problem.
                        • rigeback
                          • Mar 2011
                          • 421
                          • Malta
                          #52
                          Re: Sharp Aquos 32"
                          IC1755 Pin 1 gives 2.86V and pin 3 = 1.20V
                          On IC1725 only pin 6 has 7.53V while the TV is on, Pin 4 is still 0.0V while TV is on or off! D1725 receives 8.16V and supplies pin 6 on IC1725 with 7.53V however the nearby caps C201 & C217 have no power?? Q204 ON THE UNDERSIDE HAS 5V supply and nothing on the opposite side?
                            master hoarder
                            • May 2008
                            • 12170
                            #53
                            Re: Sharp Aquos 32"
                            The voltage going to IC1755 is a bit weak, but the output on pin 3 looks good at 1.2V, so I'll assume this is okay for now.
                            Like I said, if pin 1 has 1.8V OR LESS, then there would be no voltage on pin 4 (the output). So the IC is likely working normally. However, I traced pin 1 (it's called ANT+5V_SW, and it goes to IC2302, pin 41. So basically, IC2302 controls whether IC1725 should be ON or OFF.
                            But that still doesn't explain whether this is normal behavior or not. I highly doubt IC2302 is bad, though. More likely something else is causing IC2302 to shut down.
                            Will look in the data sheet a bit more and let you know if I find anything else.
                            • rigeback
                              • Mar 2011
                              • 421
                              • Malta
                              #54
                              Re: Sharp Aquos 32"
                              Yes you're right, I did a continuity check on this line ANT+5V_SW and IC1725 pin 1 goes to IC2302 pin 41, my meter has the diode / continuity test feature and it also gave some readings but no alarm, connecting with IC1725 pin 1 and IC2303 also BU3.3V and FB2310 which I trust is a fuse which has contiguity across.
                              Could be IC2302 is the suspend switch as when I probe it for voltage it shuts the lamps down or is duff?
                              • rigeback
                                • Mar 2011
                                • 421
                                • Malta
                                #55
                                Re: Sharp Aquos 32"
                                So what you reckon Mr. Momaka is this one gonna make it or is beyond repair??
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  #56
                                  Re: Sharp Aquos 32"
                                  Hi rigeback, sorry for the delay.
                                  IC2302 does seem to be some kind of suspend switch as it has other pins related to the TV's power, like for example pin 24 AC_DET (AC detection), pin 26 BL_ERR (backlight error), and pin 47 PS_ON (signal for powering the PSU on).
                                  I was able to find a data sheet for this IC but understood very little from it (perhaps because I didn't look at it in too much detail).
                                  Anyways, I'm not really sure what to further suggest. The missing ANT+5V voltage rail may or may not be what's causing the problem (maybe that's normal?).
                                  Perhaps the last thing you could try is pull ANT+5V_SW high by using a 100 Ohm resistor to connect ANT+5V_SW to either a 3.3V or higher voltage rail. If the TV still doesn't come on (my guess is most likely it wouldn't), then measure the voltages on pins 5, 19, 24, 25, 26, 27, 28, 30, 31, 32, 45, 46, 47, 50, and 51 of IC2302 and let me know what these voltages are. As a last attempt, I'll see if I can make some sense out of them.
                                  • rigeback
                                    • Mar 2011
                                    • 421
                                    • Malta
                                    #57
                                    Re: Sharp Aquos 32"
                                    Hi Momaka, good to have you back!
                                    You'll have to explain this part more clearly as I didn't understand from where to where I should hook up the bypass, which is cool by me. If it fails I might shop for a new board but I need to be certain that the PSU is not at fault here? It would be good to get this t-con going as it seems in fairly good shape. "The kitchen TV"
                                    I have measured the voltages on IC2302 as follows: 5=3.25V 19=3.25V
                                    24=2.21V 25=2.21V 26=3.06V 27=2.91V 28=3.22V 30=3.22V 31=3.21V 32=0.01V 45=0.01V 46=0.01V 47=3.20V 50=0.03V 51=0.20V
                                    Shorting between pin 47 & 48 also suspends the lamps same as with IC2303.
                                    Would be possible to eliminate the suspend mode to off and on, I think they use this mode in some hotels, no suspend mode to save power?
                                    • rigeback
                                      • Mar 2011
                                      • 421
                                      • Malta
                                      #58
                                      Re: Sharp Aquos 32"
                                      I found the board for 34 pounds today unfortunately all sold out including 2 other sites so I'm stuck with repairing it some how!
                                      Looking at the schematics IC2303 supplies power to IC2601 which the sends a signal to the main CPU (MY THEORY) anyway on one side it gets 2.20V and 3.24V on the center pin, on the other side nothing on both pins?
                                      I attached the data for IC 2303 so maybe you can make more sense of it, seems the IC might need programming to reset all the suspend timings etc?
                                      • rigeback
                                        • Mar 2011
                                        • 421
                                        • Malta
                                        #59
                                        Re: Sharp Aquos 32"
                                        I want to try connecting a jumper between the live 3V line and the t-con area 3.3V with an in-line 1AMP fuse to see the video can power the screen.
                                        Any comments and ideas appreciated from everyone.
                                        Thanks.
                                          master hoarder
                                          • May 2008
                                          • 12170
                                          #60
                                          Re: Sharp Aquos 32"
                                          Take a 100 Ohm resistor, connect one side to any voltage rail that is more than 1.8V (for example, B+3.3V, BU+5V, or BU+3.3V, and etc.). Connect the other side of the resistor to pin 1 of IC1725. This should turn ON ANT+5V. If the TV still doesn't work, then I don't know.
                                          The voltages on pins 5 and 19 are good. That aside, I don't know if any of the other voltages are good or not.
                                          I can't seem to find that bit of information in the data sheet for IC2302 again.
                                          Based on the pin names, my best guess would be that the voltage on pins 24, 25, and 26 need to be low (under 1V) and the voltages on pins 30, 31, and 32 all the same, and low as well. Pin 45, 46, 47, 50, and 51 high (over 2.5V).
                                          But again, all of that above is *entirely* my guess. I don't know if pulling any of the above pins low/high with a resistor can cause more damage.
                                          I don't advise you do that. Not sure what pin 48 (PCON1) does. Pin 47 (PS_ON) controls when the PSU turns on.
                                          I don't think it's possible (and if it is, it's probably very hard).
                                          Why? Is the 3.3V on the t-con not present?
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • jonah1024
                                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                                            by jonah1024
                                            Hello!
                                            I'm a few days old into this TV screens repair universe so please bear with me.
                                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                            - I did a factory reset as well...
                                            07-16-2024, 04:23 AM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
