testing vizio L32hdtv10a
  • p_trice
    • Nov 2011
    • 18
    I have a vizio l32hdtv10a that doesn't turn on fully. i plug it in and without pushing the power button, the power light turns green. I also can't turn it off without unpluggin it. I have noticed that the remote 3.3v signal that turns the power supply on fully is not existant, it shows no voltage whatsoever. I have already pretty much determined that the main board is bad. What i'm really trying to figure out now is, 1. is my power supply working properly? and 2. is my lcd inverter board working properly? I tried supplying my own seperate 3.3v signal to the remote pin on the power supply. It seems to show healthy voltages on all pins. the 24v pins are showing proper voltage, the 5v pins are showing proper voltages, and the 12v pins show proper voltage. But my main question is, if i get power supply to turn on fully with everything hooked up properly, shouldn't the backlight atleast turn on? whether there is a faulty main board or not? or does the mainboard somehow control the backlight and let it turn on? I'm showing voltages going to the lcd inverter board but none of the lights are on, and only one half of the lcd inverter board seems to have power flowing. some help would be appreciated, i'm almost at my wits end with this thing. I don't want to have to order more parts than i need.
  • PlainBill
    • Feb 2009
    • 7034
    Re: testing vizio L32hdtv10a
    First, stop and take a breath once in a while. The single long paragraph is overwhelming.
    Next, pictures help us help you. A single picture taken from directly above the main board would be appreciated.
    Vizio had a problem with U33, a 1117 class (AS1117, LM1117, etc) LDO regulator on several of their TVs. Before you get too excited, see if there is a U33 on the main board. Your symptoms do not match exactly. Or I misread what you were trying to express in the flood of words.
    The inverter is controlled from the main board. Signals to turn it on and set the brightness are sent late in the start-up sequence.
    PlainBill
    • p_trice
      • Nov 2011
      • 18
      sry for the long paragraph, i was just trying to be descriptive and thorough about the problem i am having. I'm not sure where U33 is located on the main board. I have looked and looked but most of the letters and numbers are too small for me too read. I tried to attach a pic of main board but it won't upload for some reason. So your saying that the lcd inverter won't turn unless instructed by the main board or? So if i replace the main board, will the tv work properly again?
      • retiredcaps
        • Apr 2010
        • 9271
        You know this is the 2nd time PlainBill and others have told you to check U33.
        From your previous thread ...
        https://www.badcaps.net/forum/showthread.php?t=17312
        Note the picture restrictions/instructions/limitations below.
        --- begin sig file ---
        --- end sig file ---
        • p_trice
          • Nov 2011
          • 18
          i have looked and looked, i can't find U33. could someone point out to me where in this picture u33 is?
          • PlainBill
            • Feb 2009
            • 7034
            Not on that picture. I can barely count pins on the LDO regulator, let alone component IDs. You may have a different main board.
            If you look at the picture, near the top center is a symbol consisting of an interlinked LF (probably indicating Lead Free). Just below that symbol is some text, to the right of the text is an LDO regulator, it probably has a part number of AS1117. Note that pin 1 is on the bottom, the middle pin and the tab are identical. U33 (if it exists) will be identical to that. There is another IC in an identical package about 1/3 of the way up from the VGA input (blue) connector.
            With the main board and power supply screwed in place, the TV plugged into an AC outlet, and power on, measure the voltage on the three pics of each IC in an identical package. Report the results.
            PlainBill
            • p_trice
              • Nov 2011
              • 18
              yea, my camera is kinda crappy. sry for the blurry pic. I tested with voltmeter and found no voltages whatsoever on any of the pins for the components u mentioned. And I am pretty much certain that this board has no U33. I looked for hours.
              • PlainBill
                • Feb 2009
                • 7034
                Have you checked for fuses on the main board?
                PlainBill
                • p_trice
                  • Nov 2011
                  • 18
                  yes, there is one fuse on the board. I checked it with a test light, it is in working order.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Then without better quality pictures I can only suggest you buy a replacement main board.
                    PlainBill
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      by ygorsan
                      🧩 Problem Summary:
                      • I
                      07-28-2025, 08:34 AM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • JDC
                      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                      by JDC
                      ONN 100012588
                      Issue: No Power, Then Rebooting After Main Board Change
                      Short answer: replace main board and power board
                      Technical answer: replace main board and Q306 & Q307 on power board.
                      Long answer:
                      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                      07-15-2022, 07:39 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
