Sony 40 in LCD, no video no sound.
Re: Sony 40 in LCD, no video no sound.
What is really needed is a better picture of that area, and the part number of the square IC so we can figure out what is where. Way back when I was getting started in electronics I built a signal tracer - essentially an audio amp and a speaker. With a cap on the input to provide DC isolation, it was easy to trace audio signals. Not as good as an oscilloscope, but a lot more portable.
By the picture, this is a class D audio amp. Very little to troubleshoot; all you need to do is verify audio signal and power in, and trace the signal out.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Ok, thanks to all. Sound works. It helps to have the manual. Without it, I figured that when I have HDMI in, I would choose the HDMI for the Sound-out.Not the case, I had to choose HD15 from the menu and then low and behold perrfect sound. Thanks again to everyone.
CHEERS!!
CHEERS!!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hi:
I picked up 2 Sony monitors at work that had both stopped working,they were going to the landfill. The model numbers for both is FWD-40LXF2F. Company had them playing 7 days a week 24 hrs a day.Both are in my garage which is about 40 degrees right now. The problems are:
TV1:It will play perfectly for about 10 minutes then There will be a high pitched sound from speaker and I will lose the picture. If I unplug the Monitor and plug it back in it comes back on for another 2 minutes and goes off again. The sound is good and I did a back light test. Doing the flashlight test there is no video present. I swapped the power supply with TV2 and got the same result.
TV2:
The problems are no video,no back light and I am unsure if the sound works. Again I had swapped the power supply with TV1 with same result as before.
So I feel there are no issues with the power supply in both cases and am leaning to the main board for both tvs. Would like to figure out what is wrong. Visual inspection showed no burned areas or bulging caps. Any help will be great.Comment
by soerenI am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
All happened after the battery ran out of power overall several days when I was on vacation.
I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery... -
TCL LED TV Service Menu Code
LG LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by IerwinHello everyone,
I got a 58pus7805 that shows some weird behavior.
The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
I managed to install the latest official firmware by holding the control button while plugging... -
by FrancescoVGood morning everyone,
I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
The firmware reported is the following:
M:1.00/11107BLP
D:?.??/????????
O:1.00/11107AL
The DSP firmware given the question marks seems corrupt.
On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...-
05-11-2025, 02:59 AM -
This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...09-12-2024, 02:00 PM
- Loading...
