f&h 19"lcd
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    f&h 19"lcd
    hi,im replacing a capacitor on this tv,its on the main av board,the spec of the blown cap is as follows
    FCON GL SERIES 470uf 16V 105 DEGREE
    SIZE 8*12MM
    RIPPLE 600
    ESR 0.162
    the cap im replacing it with is
    PANASONIC FM 470uf 16V 105 DEGREE
    SIZE 10*15MM
    RIPPLE 1240
    ESR 0.041
    is this a suitable replacement for the fcon?,any help would be much appreciated,thanx guys
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: f&h 19"lcd
    SIZE 8*12MM
    RIPPLE 600
    ESR 0.162
    Panasonic FC would be a closer match to the original cap specs.
    Ripple = 730, esr = 90 mOhm according to digikey.
    http://search.digikey.com/us/en/prod...0247-ND/266256
    --- begin sig file ---
    --- end sig file ---
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      Re: f&h 19"lcd
      would the fm be not better with the higher ripple and lower esr?,i only say beacause ive done some research on all these great pages of badcaps and seem to get mixed opinions on lowering esr can be bad for a board?,its all rather confusing!,yet most seem to recommend the fm series,?,help!
      • mariushm
        • May 2011
        • 3799
        Re: f&h 19"lcd
        fc < fm <= fr .. fr has bit higher esr than fm but it's longer life.
        In general lower esr is better but in some rare cases, going to very low esr when the original caps were average esr can hurt...
        I'd say either ones would be Ok, make sure you have 10mm diameter room on the board for the fm series if you choose that.
        • retiredcaps
          • Apr 2010
          • 9271
          Re: f&h 19"lcd
          PCBONEZ explains it at
          https://www.badcaps.net/forum/showpo...30&postcount=7
          In the LCD and TV forum, we tend to recommend Panasonic FR, FM, and FC from digikey. Sometimes we "blanket" recommend FM because sometimes we cannot find any info on the original cap.
          Other times, we already know FM is a good replacement for x, y, and z because of previous homework/research.
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            Re: f&h 19"lcd
            Other times, we already know FM is a good replacement for x, y, and z because of previous homeword/research.
            that was excellent reading retiredcaps i never saw that page!,and also thanx to mariushm i seem to understand a little better now,i am the type to try and match specs on everything when repairing,it just gets a little confusing hearing different bits of advice and not knowing what to actually go with,id like to get an idea ,ie,what grade of caps for a psu,what grade for a av board,and grade for inverter boards,and try to stick with one manufacturer,ie panasonic fm and fc would be great!,that narrows the worry down to just 2 grades of caps,instead of 100's !,and then match to the specs of the origonal cap that needs to be replaced,god my head hurts now,
            • mariushm
              • May 2011
              • 3799
              Re: f&h 19"lcd
              I usually pick Panasonic FM, FR and Nichicon HM, HN, HZ (but this one is harder to find) - both are reputable companies and these series have reasonably low ESR and high enough ripple.
              Another good capacitor series imho is the United Chemi Con KZE series and I also like Rubycon (RX series for example is rated for 130c) but this last brand is less recommended on this forum because the well known digikey.com online store doesn't stock them. Farnell (Europe seller) does and I use it.
              They're almost always better on paper than random brands of capacitors.
              In just some cases, I have to look up alternatives due to the diameter of the capacitors - the Panasonic caps tend to be larger in diameter than the original capacitors.
              • chth96
                Can I replace KME cap with Samxon GF cap?
                by chth96
                Hello.
                I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                04-17-2024, 07:11 AM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • Antonynl
                What are typical ripple voltages on a laptop motherboard?
                by Antonynl
                I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                So I have two questions:
                1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                12-09-2022, 06:51 AM
              • dumblejd
                rtx 2080 GPU capped at 60 degree
                by dumblejd
                My friend has a evga rtx 2080 super, and with liquid cool backplate. I installed for him. 4 month ago it runs good, and recently idk if he played with msi afterburner or not, the gpu slow it's core frequency when it's over 60 degree. I reset setting in msi afterburner, still the same.
                here is a video of it running stress test, the usage is always 100% for sure, but core frenquency drop to 300mhz (should be over 1600mhz normally), when it hit 60 degree.
                https://imgur.com/a/gLMfJid
                at very beginning of stress test, the frequecy can reach 1600+, but as...
                12-11-2022, 11:17 PM
              • Ady2017
                Is there a manufacturers tolerance for ripple?
                by Ady2017
                Hi all
                I need to replace a 680uF 35V SamYoung NXB cap which has got a ripple of 1820. Whilst passing my local little electronics shop I picked up what they had in stock which was a 680uF 35V Panasonic FC with a ripple of 1655.
                As the ripple rating is only 9% below what the original was I am wondering whether to risk it and fit it.
                The catalogues specify a capacitance tolerance of +/-20% but state nothing about the ripple. If there is a similar tolerance for ripple then I might be worrying about nothing. Does anybody know?
                11-13-2021, 11:46 AM
