The tv would start to come on but then would go back to stand by. i check the power board and found a cap that was swollen up. i replaced it and after putting it back together i cant even get a power light? does anyone have a solution? thanks alot
Panasonic tv tba-03211c has no power
Tags: None
Re: Panasonic tv tba-03211c has no power
https://www.badcaps.net/forum/showth...t=10017&page=5
I just finished fixing a similar Polaroid TV (TLX-03210b). There are two 10uf 450V capacitors that need to be replaced. I replaced both of them on my set and it's been working for 2 1/2 weeks now. One of the capacitors was obviously bloated, but the second one was not.Comment
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by Green Probe(TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
Disclaimer: I'm an amateur hobbyist and will get things wrong.
Always use caution when working around mains power and high voltage capacitors!
Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
SYMPTOMS:
-No display...-
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
