Samsung LW26A33WX - no backlight (sound is good)
    Got this from the local tip for cheap, thought I would have a go at fixing it. Anyway when powered on it does the Samsung chime but nothing appears on the screen. I tested the inverter transformers and found #4 to be failed (open secondary; all others measure ~1.5kohm.) I'll report back if it is fixed by a new transformer.
  • pjvansteen
    • Jul 2010
    Re: Samsung LW26A33WX - no backlight (sound is good)
    Hi tom66. did you fix youre problem with a new transformer?
      Yep. Sorry, I forgot to post back. TV works great.
      • bbjunkie
        • Dec 2011
        • 301
        Another easy fix congratulations tom66
          Only £20 from the local tip and £10 to fix, sold it for 3x that. And another TV saved from landfill.
          I also fixed a 37" Philips LCD TV (my first 1080p set) with a new transformer. Very common failure on Darfon boards.
          • Paul678
            • Nov 2011
            • 402
            I've got to chime in that the spirit of this website is the
            coolest.
            Not just for making a few bucks and having
            some fun (and frustration!), but preventing a general
            waste of resources, and discouraging the disposable
            nature of the world's consumerist culture, where
            new things are preferred over used.
            Good work.
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Max514
              Samsung UN55H8000 sound but no backlight no video
              by Max514
              Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
              The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
              I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
              • Unplugging the main board cable at the power supply >>> backlights came on.
              • BLU_ON signal from the
              04-14-2022, 10:34 AM
            • totof
              LG 43UF640V backlight good but black screen and no sound
              by totof
              Good morning.
              I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
              I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
              In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
              HVDD : 7,28...
              04-13-2024, 11:37 PM
