Bypass LCD TV Inverter Board Shutdown Backlight?
  • gorr35
    • Nov 2010
    • 127
    "How To Bypass LCD TV Inverter Board Shutdown Backlight System" Has anyone seen this article before (Below)? Has anyone tried it? Sounds pretty dangerous to me. Supposedly it is to check to see if your CCFL Lamps are out when you get sound but no picture, or if it's the inverter board itself. Do all LCD TV's have a similar chip with the same functions?
    http://www.bestelectronicarticles.co...ht-system.html
    Re: Bypass LCD TV Inverter Board Shutdown Backlight?
    I think it could easily damage a transformer or driver FET if the CCFL is shorted or open, due to either high currents on the primary, or high voltages (due to lack of load.) Maybe...
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      It won't short any FETs because the controller's also got got current sense... but yes it could damage a transformer by arcing if the CCFL is open. Best bet is still testing the CCFLs with a spare board.
      A working TV? How boring!
      • Jrolfe
        • Sep 2011
        could this problem cause a strobe effect for about 10 or 15 minutes and then go away? In other words, my Vizio VX42L strobes the screen for about that long, then the screen straightens out and looks great. I was told that the CFFL was failing and the only repair was to replace the extremely expensive LCD screen. Does that sound right?
        Thanks,
        Jeff
        • PlainBill
          • Feb 2009
          • 7034
          Thanks,
          Jeff
          That sounds like someone wanted to take an 'unrepairable' TV off your hands cheap. Well, let me be correct. A service shop affiliated with the manufacturer may have no choice except to replace the LCD panel (which usually includes the CCFLS and the inverter).
          I would suspect a capacitor, but I haven't dug into the workings of the inverters Vizio uses.
          Here is a quick background. Every inverter I have seen uses an 'inverter controller' to provide a stable output, and provide safety features in case of an aging or broken CCFL. I have not performed an exhaustive review, but in every case I have researched, if a problem 'trips' the protection, the inverter shuts down and stays down until reset.
          Next, there is the fact that 'strobes' is ambiguous. I tend to think of a strobe light used to freeze motion. This turns off completely. IF the panel on your TV is flickering (getting brighter, then dimmer, but always staying on), yes a bad CCFL could be causing that. It IS common with a CCFL failing due to age or a defect. As I said above, it can also be caused by a bad capacitor.
          There are many different layouts for LCD displays, but in general, while the manufacturer says they are unrepairable, the fact is CCFLs are replaceable by anyone with decent mechanical skills.
          PlainBill
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • lostone
            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
            by lostone
            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
            05-19-2024, 11:40 AM
          • jimbofz
            lg 32LC46 backlight inverter board fault
            by jimbofz
            Hi this oldie had no backlight .after replacing caps on 24v rail ,
            still no b/l this uses inverter type:1315 B1-16A,
            im sure ive come across the same inverter in a samsung possibly le32r88bd ?
            all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
            this allows protect to be temporary overridden.
            b/l now comes on
            but the left hand side of pic is gradually darker than the right side
            i have the cct for the tv
            but it does not have inverter cct.
            i opened it up to inspect the ccfl tubes
            and they dont have any...
            12-19-2021, 06:58 AM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
