Vizio SV421XVT No Power
  • 1beertap
    • Mar 2009
    • 219
    I just got this lcd tv today. The first thing I tested was the main fuse. I noticed the fuse had soldered leads going to board and one was broken. I repaired it. Now, I have 5v standby coming out at power supply going to main board. Next, I noticed that the screen didn't come on when I tried to power it up. So, I checked for 5 volt standby at the main board and found a smd fuse (LF5A) to be blown. My thought was that maybe the main fuse problem caused the smd fuse to blow due to power interruptions. I got a regular 5 amp fuse 32v and put in the circuit. It blew as well. I know I have a shorted component, but where? Does anyone have schematic for this tv? Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Vizio SV421XVT No Power
    It doesn't affect the problem, but your theory of why the fuse blew doesn't make any sense.
    Use the standard troubleshooting technique for this problem. Hook a 5V current limiting power supply to the load side of the LF5A fuse. Increase the voltage and current limit for no more than 3A. This will PROBABLY be at less than 1 volt.
    First step - gingerly trace the 5V standby line. You are looking for a component that feels warm. Likely candidates are LDO regulators and SMD capacitors. If you don't find something heating up, it gets more tedious.
    Set your DMM to the lowest voltage scale. Place the red lead at the point on the board where the external power supply is connected. With the black lead follow the 5VSB rail noting the voltage at each component connected to the rail. The voltage drop will increase slightly as you get further away from the injection point. At some point it will stop increasing. The short is at that point.
    PlainBill
    • 1beertap
      • Mar 2009
      • 219
      PlainBill, what you said made perfect sense. I thought about using the old light bulb trick but decided against it. Instead, I ordered a new power supply with adjustable voltage and current to do the job. All of the power supplies I have, currently, are regulated and have a fixed voltage and amperage rating. It'll be here in a few days and I will test the main board and report my findings. Thanks PlainBill - you're the man!
      • PlainBill
        • Feb 2009
        • 7034
        Well, you could have probably done it with a 5V supply and a light bulb to limit the current, but it doesn't have real fine control. To point out the obvious, set the bench supply to provide 5.0 volts maximum.
        Way back in my youth the test department had a variable supply that would put out 15V at 10 amps or something ridiculous like that. The technique I outlined above was a popular way to locate shorts.
        The problem was some techs would sometimes get careless and crank the voltage upto 15 volts, then increase the current. The problem occurred when they located the short (quite often it was a ceramic bypass cap) they would get excited and cut it out. Of course, then the supply would be feeding 15V into a 5V rail and all the little TTL ICs would short.
        PlainBill
        • 1beertap
          • Mar 2009
          • 219
          Just a little update, I finally got the adjustable power supply to test the main board for the short. I set the unit to 2.5V at 1A and connected black to ground and red to the load side of the blown fuse. I found one ic getting extremely hot (part #4953GM). It is a 30v 5A power mosfet. So, I ordered a replacement and a fuse. I will post my findings as soon as the parts arrive.
          • PlainBill
            • Feb 2009
            • 7034
            Good work. While you are waiting for the IC, check the load side. The short may be 'downstream' from this.
            PlainBill
            • 1beertap
              • Mar 2009
              • 219
              I decided to just replace whole main board since I was unable to obtain a schematic. Trying to trace all the paths of a circuit on a multi-layered board is difficult at best. After placing the new board into the unit, the television is now working. I will keep the older board for parts. Thanks for the help PlainBill.
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • mkdj
                Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                by mkdj
                Dear all,
                I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                Both N-Channel Mosfets: nothing odd
                P-Channel MOSFET number 1:
                source - drain : 117 kOhm
                source - gate: 96 Ohm
                gate - drain: 117 kOhm
                P-Channel MOSFET...
                08-20-2025, 06:08 AM
