Toshiba 47zv650u no power at all!!
  • rmoody
    Learning Member
    • Jul 2011
    • 262
    Re: Toshiba 47zv650u no power at all!!
    C820 and c821 both read .004 volts. Getting nothing on them at all.
    • PlainBill
      • Feb 2009
      • 7034
      Argh!!! Working two different power supplies and getting confused!!!
      The bridge rectifier is on the heat sink labeled D820A. AC voltage is applied to the two center leads; DC voltage comes out of the two outer leads. What are the AC and DC voltages?
      If both AC and DC voltages are present, I AM going to need a better picture of the bottom of the board.
      PlainBill
      • rmoody
        Learning Member
        • Jul 2011
        • 262
        D820A
        started out @ .930 AC and slowly built up to over 1v kind of like the meter was charging it.
        DC started out @ .630 DC and slowly started building.
        • rmoody
          Learning Member
          • Jul 2011
          • 262
          got a glare on the pics but let me know if there's a more focuse area you would like a pic of.
          • rmoody
            Learning Member
            • Jul 2011
            • 262
            This would be much easier with a shematic or service manual. Have you searched for the power supply manual? it's PE0702. I can't really find anything on it either but thought you might could.
            • PlainBill
              • Feb 2009
              • 7034
              Yes, it would. I haven't been able to find anything.
              Pardon me while I do a complete reset.
              I've marked up the picture of the bottom, and I think I am getting closer. With the power supply connected to AC, measure the following points. All should be AC voltages. A1 to A2, B1 to B2, C1 to C2, D1 to D2, E1 to E2, and E1 to E3.
              PlainBill
              • rmoody
                Learning Member
                • Jul 2011
                • 262
                #27
                PlainBill
                a1-a2= 124v
                b1-b2= 124b
                c1-c2= 124v
                d1-d2= 124v
                e1-e2= 1.4vac and slow rising
                e1-e3= 124v
                • PlainBill
                  • Feb 2009
                  • 7034
                  a1-a2= 124v
                  b1-b2= 124b
                  c1-c2= 124v
                  d1-d2= 124v
                  e1-e3= 124v
                  OK, and now to figure out why. I'm going to need a better picture of the area outlined in white in the attached picture. If at all possible, take the picture in a well lit area.
                  If you look at the corresponding area on the top of the board there are two relays. What are the part numbers of them?
                  PlainBill
                  • rmoody
                    Learning Member
                    • Jul 2011
                    • 262
                    #29
                    I was suspect of these relays in the beginning because the board had a lot of work done one it before with someone trying to get it working and I believe one of the relays had been replaced.
                    sr80= lkt1af-5v
                    sr81= Omron g5pa-1, can't read any more of this relay without taking out of circuit.
                    • rmoody
                      Learning Member
                      • Jul 2011
                      • 262
                      #30
                      Here's the best pic I can get at the moment.
                      • rmoody
                        Learning Member
                        • Jul 2011
                        • 262
                        #31
                        OK Bill, Here's my situation on this. When I opened the back there was a bag of screws for the back panel and power board and it also had one of these relays in it. Here's how i found it:
                        sr80= Omron 5Vdc
                        sr81= Lkt1af-5V dc
                        The relay in the bag that had been pulled is another Omron but it's a 12V. My thinking is He maybe put the wrong relay and possible even switched up which one is supposed to be a 5V and which is supposed to be a 12v. Any way to figure that one out?
                        • rmoody
                          Learning Member
                          • Jul 2011
                          • 262
                          #32
                          Oh and i tried checking resistance on the 3 relays and the 2 5V relays were 100 & 103 Mohms. The 12V is .270 Kohms which makes me believe it may be the bad one. Which was pulled when I got the TV
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Those pictures clear thing up. What is the information (value) printed on R850? And with the power disconnected, what resistance do you get?
                            PlainBill
                            • rmoody
                              Learning Member
                              • Jul 2011
                              • 262
                              #34
                              PlainBill
                              R850 reads up to 17 Mohms and then starts falling off lower.
                              Its labeled
                              RGDU5M-5E
                              1.8 OHMS J
                              NOBLE 98
                              • rmoody
                                Learning Member
                                • Jul 2011
                                • 262
                                #35
                                Just a little FYI, I pulled the caps off of the relays and neither of them are closing when power is applied. So i set my meter on the connectors for main and inverter board and I activated the relay and when I did, I immediately got 12Vdc. My problem seems to be lying right here close to these relays. Maybe that resistor I tested earlier. That sounds High to me.
                                • rmoody
                                  Learning Member
                                  • Jul 2011
                                  • 262
                                  #36
                                  OK Bill, I ended up finding a power board shipped to my door for $50. I compared some of the values from the good board and that resistor you had me check is definitely bad. Anyways on to the next thing. I got the board in and now it powers on and displays for a few seconds but I'm getting a buzz from the inverter boards. Seems like master and slave have the same sound. I recorded a video and posted to photobucket if you would like to watch it and see what it's doing. After it buzzes a few seconds It shuts down and gives 2 series of 3 flashing orange lights. The inverters shut down after just a few seconds.
                                  http://s1005.photobucket.com/albums/...urrent=011.mp4
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Yes, that resistor was definitely bad. It bypassed the contacts of the relay to provide standby power which would turn the relay on. Replace it and you will have a spare power supply.
                                    I think you uploaded the wrong video.
                                    You know the drill - pictures of the inverters.
                                    PlainBill
                                    • rmoody
                                      Learning Member
                                      • Jul 2011
                                      • 262
                                      #38
                                      PlainBill
                                      Will get some pics of the inverters. Its very weird to me that both could be bad. Could this be caused by something bad on the new power supply? it has 24 volts at the connector. Main inverter is under the main so I will have to remove it again for a pic. Could this be from maybe a lightning strike or power surge? The video was just so you could hear the buzzing and see the backlights turning on and back off.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        A Power surge / lightning strike can cause damage at multiple points. You have indicated you obtained the TV in a non-working condition. There is a long tradition of less than ethical 'technicians' (to use the term very loosely) jamming a number of bad parts into a TV and selling it as 'It just quit'.
                                        PlainBill
                                        • rmoody
                                          Learning Member
                                          • Jul 2011
                                          • 262
                                          #40
                                          Got the tv to quit buzzing for a short time but it started after 10-20 seconds and eventually shut the unit down again. Here's some pics. One of the slave had quite a glare.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • ju123
                                            Toshiba Satellite C50-A won't power down
                                            by ju123
                                            Hi guys,
                                            So, I've been racking my brains on this one.
                                            I have a Satellite C50-A which I'm repairing for a friend.
                                            I recently replaced the main board due to failure.
                                            Following this, absolutely everything works perfectly, except for the fact it won't power down.
                                            Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                                            01-07-2022, 04:40 PM
