Philips 42" 715T2432-2 issues
  • skelator2112
    replied
    Re: Philips 42" 715T2432-2 issues
    Ok guys I see all above was posted awhile back, hope someone has a fix for this other than replacing the entire power supply board. But still at 270 its better than a new set at over 1k. I replaced the 3 cap that were slightly domed,, issue continues, no pic and chirping ZD904 /02 look like there "might" be an issue there but as above I'm thinking (non-qualified) it might be the transformer last numbers in a string of ,, a lot,,, J737.
  • edtv
    replied
    Replaced three shorted diodes and same chrip. Not resolved. Left to believe the small transformer is at fault...
  • edtv
    replied
    Diode zd904 has short. Will replace and give update
  • edtv
    replied
    Exact same problem here...
    Replaced all 4 caps then removed center transformer but I can't identify the diodes you speak of. I don't know if these pics are any better but would can point them out please?
  • cadiman
    replied
    I also have picked up a few tvs that were recapped and found bad diodes in the power supply.
    The chirping is start up attempt as Plainbill said.
  • Dgtech
    replied
    I'm just curious why three out of the four caps were replaced? Change the last one just to rule it out. Also, there are two diodes beneath the transformer that look like they took a little heat.
  • rayrod81
    replied
    I have worked on quite a few of these LG Philips power supplies lately and have found that a shorted transformer is the culprit most of the time. Unfortunately you will not be able to find a transformer anywhere and have to replace the whole supply if that is the problem.
  • PlainBill
    replied
    Originally posted by Omyn
    I replaced the cluster of 3 with the caps found at this link
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
    One of the connectors goes to the power on switch which has an led. The led is lit and changes from red to green when pressed. The chirping only occurs when the power button is switched on. The power button turns green but the screen does not turn on.
    As for the pictures, I apologize. I could not get my camera to cooperate with flash. The reflection took away everything that could be seen.
    If they are genuine, those caps should be excellent.
    Good information. That points to a problem with the main power supply. It appears there is only one output from the main supply and the diode on the large heat sink at the top of the first picture rectifies it. Make sure that diode is not shorted.
    Many of us have found that taking a picture during daylight hours without a flash gives the second best results. The best pictures came from someone who had his own indirect lighting setup, but most of us can't justify the space for something like that.
    One other possibility is a short in the load. There is a popular line of inverters supplied by LG that are notorious for causing problems.
    PlainBill
  • Omyn
    replied
    A chirping sound like that is often due to an excessive load, or a bad startup cap.
    Which capacitors did you replace, and what brand and series did you use for replacements?
    I notice three output connectors. Is there any indication of the function of any of the pins on the connectors?
    Also, please read this post, then review your pictures in that light.
    PlainBill
  • PlainBill
    replied
    PlainBill
  • Omyn
    started a topic Philips 42" 715T2432-2 issues
    My phillips 42" LCD is having power issues. Upon taking it apart and examining the power supply, I noticed 3 of the caps were bad. Replacing these 3 caps did not resolve the primary issue. The transformer in the center is producing a consistent repeating chirping sound every second or so. I've repaired leaking caps in the past but never had to deal with an issue like this. Any help is appreciated. Thanks
    by momaka
    03-12-2025, 03:42 PM
  • SluggerB
    Can't find exact matching caps for replacements, what should I get to prevent video issues?
    by SluggerB
    I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
    I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
    The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
    04-05-2024, 07:47 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • captain150
    by captain150
    03-16-2025, 07:34 PM
