Samsung B4K-50 PSU
  • Tommy100
    • Jul 2011
    • 10
    Samsung B4K-50 PSU
    Hi guys, sorry to duplicate a thread.
    I have posted on https://www.badcaps.net/forum/showthread.php?t=8831 as well, this is just a Bump.
    My PSU has exactly the same damage, and I do not know if IC2 is avalable in South Africa.
    Does anyone know what the Output Voltage is of the Standby supply?
    I have a nice small Casio printer SMPSU that gives 24V 0.8A and I would like to use it as Aux supply. (with the blown components and Primary and secondary rectifier / Caps removed.)
    If anyone has a copy of the psu cct diagram they can share It would be most appreciated.
    Thank You.
    Tom.
  • PowerAmpFreak
    • 982
    • Sweden
    Re: Samsung B4K-50 PSU
    The chip is probably the ICE2A280, not IEC2A280 that incorrectly stated in your other thred.
    • Tommy100
      • Jul 2011
      • 10
      Removed all the blown components and ones that look like they might pull down an external supply.
      If I remove D28 on the Secondary of the Transformer and apply 5Volt to the smoothing cap, I can get the remote / power light to come on and switch with the front panel.
      But nothing else happens power wise. The Aux supply seems to feed a 18V Regulator, but I cannot feed it from a bench supply as the negative of that section is hot.
      The printer supply I wanted to use cannot supply sufficient current so another plan is needed.
      It seems the repair shop in my Area replace the whole B4K and do not do component level repairs.
      The ICE2A280Z seems to be unobtainable here in za. Sighs..
      • Tommy100
        • Jul 2011
        • 10
        Removed the 18V regulator and used a HP Printer supply 18V. It is a smpsu and the secondary is well isolated now all I need is a sturdy Compaq 5V charger, tidy up the mods and its tv time!
        • Tommy100
          • Jul 2011
          • 10
          Used a 18V Compaq supply with an lm7805 on heat sync, the heat sync can be earthed for neg, and the 5V connected to where D28 was, C39+.
          Neg from the supply was put on C39-.
          The HP Printer 18V supply Secondary is well insulated and it was connected to where IC8 was. + to output of IC8 and neg to the earth, center leg.
          The input supply was taken from across CX4S pins.
          Both smpsu`s used have built in fuses.
          The only function that is not working is the standby relay, dont know why. But the set switches on nicely starting in standby, with the led yellow.
          Then the front panel switch or remote can be used to switch on.
          To switch off, I switch to standby, then power down.
          Well this was a Bush repair. :p But its working, so happiness is.
          Cheers.
          Tom.
          • Tommy100
            • Jul 2011
            • 10
            The two units were mounted above the main psu, but its a bit hot there. They are not obstructing the flow from the Heat syncs. Its just warm up there with the lid closed, so I will put in 2 Boxer fans till The components can be scourced.
            • trosdepep
              • Jul 2012
              • 70
              • Spain
              Hey!!! Tommy100, I have same problema than you. I explained my problem on thread that you mentions on first post.
              I solved the problema using your invention
              Now tv Works perfectly and I have solved the problem of standby relay to open and close. Now is not heated in standby mode.
              Is very easy. I´ve connected a 19v psu to the cathode of D25 instead of connecting a 18v psu on IC8
              • Tommy100
                • Jul 2011
                • 10
                happy days! Mine is still working as well!
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  09-07-2024, 05:50 AM
                • cheeky2
                  Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                  by cheeky2
                  This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                  I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                  Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                  06-15-2025, 05:12 AM
                  03-31-2024, 02:12 PM
                • UglyBetty
                  Need some help with Epson Printer Power Supply C655 MAIN
                  by UglyBetty
                  Here is the back story. This printer had been sitting for about two years not used. I removed the print head to clean it (completely dried out). I cleaned it and reinstalled in. Powered the printer on, the printer started going through it's normal start-up procedure and part way through it was like the power just shut off. No sound, not lights, no error messages, it just went completely off. I suspect the power supply.
                  At any rate, the schematic for the power supply is included.
                  There is a lot going on on the low voltage side that I am not able to make heads or tails...
                  01-06-2022, 03:54 PM
