Gotta free Phillips plasma mod. 50MF231D/37, chassis EP1.1U, that the owner replaced two 16V 3300uf caps on, (C8059 & C8060), on the PSU or power supply board. No/picture or sound. So far I've downloaded the service manual, but alas, the main power supply is not included in the schematic, but for some odd reason the DC to DC converter on the SSB is???
Main power fuse was blown, but replaced and it holds. 1V, 3V, 12V, 18V, 200V supplies power up and ripple looks okay, but error 14, (Audio supply Class D amp) is shown when SDM or service diagnostic mode is entered.. green front panel led shows 1 long flash & 4 short.
Voltage on audio amp supply rails is +11.9 & -11.9. Voltage on speaker wires is ~0.05volts. Leds 8001 & 8002 on PSU are both on steady which I think is good. The DC_PROT line between the PSU board and the SSM, (small signal board) is at 0.06V. On the SSB I can't seem to get on the U_Volt-Detect, H_Volt-Detect or Prot_Audio supply lines to measure powered up, as this is on the bottom of the SSB..unmarked surface mount components, very small and hard to reach while connected etc. Anyone fix a similar error problem on this unit? Seems a shame to trash it...
