Help, BENQ DV3250-SA
  • xrockonx
    • Jun 2011
    Looking for some help, im new to this.
    I just got a benQ DV3250 that someone was getting rid of because the screen wont work. Took the thing apart last night and I can't tell if any of the caps are bad, ive seen toasted caps before and all these (that i can see) look fine. Is there some other way of testing each cap? Or maybe thats not my problem.
    When i turn the tv on, i can hear the fan start up in the back and the screen flicks on for a second then goes black.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Help, BENQ DV3250-SA
    Caps are best tested with an ESR meter (such as Bob Parker's Blue ESR meter), or with something like RusMike's combo ESR and capacitance meter (look in the 'Test Equipment' subforum). Don't forget, many manufacturers have figured out how to produce caps that fail without any visible signs.
    The symptoms you describe sound like 'Two Seconds to Black', which can have a number of causes, including bad caps (especially in the inverter), a bad CCFL, bad wiring to the CCFLs, or a bad transformer.
    PlainBill
    • xrockonx
      • Jun 2011
      thanks, ill start testing caps. Anyone have a technical manual for this tv? i cant seem to find one online
      • BustedTVaU
        • Jul 2014
        Did you ever find out the problem with your tv? I have the same problem. I can hear the fan start when I turn the power on and it does a quick attempt to turn on while making this electrical flicker sound while the screen flashes quickly but then screen goes black again.
        • selldoor
          Slow Learner
          • 7870
          You have got to be having a laugh
          This thread is 3 years old!!! If you want someone to help you will need to
          open your set up take a good clear picture of the insides showing the setup then good clear well lit but not flash pictures of each board.
          Have a look at other tv posts and see what is generally required.
          Sounds like it could be Bad bulbs/ wiring so first thing to try is to unplug
          clean where possible an replug all connectors
          Say what you electronic experience is and if you have a multimeter/soldering equipment.
          Was it your set - any history leading up to failure.
            by momaka
            03-12-2025, 03:42 PM
          • Noodneek
            Replacing all the caps on the BenQ SW2700pt's power board didn't help...
            by Noodneek
            My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
            I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
            08-30-2024, 12:52 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
