Need Help or advice about my tv
  • kscott
    • Jun 2011
    I have a 50"HDTV Sanyo Plasma tv that has one vertical purple/pinkish line on the left side. It is always there but is more noticable when light or bright colors are on the screen. Even shows up on screen when a dvd plays so I know it is the tv screen not the tv channels. What is this and how can I fix it? Thanks for any input.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Need Help or advice about my tv
    It is caused by a bad buffer or by a bad bond. Some buffers are on an external board and can be replaced. Others are bonded to the flat flex strip that is an integral part of the panel. It could also be caused by a failure inside the plasma panel itself. The last two failure are considered unrepairable.
    PlainBill
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • ipatch
      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
      by ipatch
      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
      08-24-2024, 02:36 PM
