could some one tell me where to find a schematic for the lg 32lc2d power supply as i cant seem to find that or its staring me right in the face but i cant see it any way its the one with p102,p102,p103 etc on the psboard thanks for any help i can find the manuel l61 chassis but i cant find the power board.
finding a schematic
Re: finding a schematic
Here you are check is yourseft
http://elektrotanya.com/?q=showresul...oria=&kat2=all
Find the website
http://www.fixya.com/support/t376851...blinks_but_set
change your adc(analog to digital converter) board will help outLast edited by hoadle; 08-24-2011, 08:55 PM.
by LA1I am trying to find two smd datasheets for an Apevia 1000w prestige power supply ATX-PR1000W the SMD's are ST9S313 which is a SMPS supervisory chip and a EST 915HP or XP48024 not sure which or both is the chp prod number and the schematic
by pdosystemHello, does anyone have a hp zbook 17 g5 - DA0XW3MBAH0 REV-H schematic or board view? I would be glad if you could share it.
by GfilipeZHi,
I'm diagnosing a machine that won't turn on.
When I did the visual inspection under the microscope, I detected a blown IC next to the USB-C connectors.
But i can't find this IC on schematic neither boardview.
I send attached pictures of the IC and its location.
Does anyone know if there is another version of Logic Board, which has this IC on schematic and boardview?
Best regards.... -
Channel: BIOS Requests ONLY!
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... - Loading...
