Insignia NS-LCD37 Service mode code.
  • truep
    • Aug 2010
    • 373
    Does anyone have the service code (from the remote) for this set. I can't locate the service manual and the code for the LCS-37-09 doesn't work.
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • AustinCER
    Dell XPS 8940 | Manufacturing Mode? | No Service Tag
    by AustinCER
    Hello, I currently have a Dell XPS 8940 in our office for repair.
    Service Tag: HG1Y673
    The most recent BIOS is pictured below -- being available as an .exe on Dell website.
    Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
    Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
    07-15-2025, 05:28 PM
  • RRice25541
    Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
    by RRice25541
    So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
    the color is all outa wack, like the settings have been corupted,
    I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
    so
    The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
    when i bring up the menu and type the pass codes to access either mode the menu disappears...
    05-13-2022, 10:44 PM
  • thesame
    JVC LT-40V750 stuck in service mode switching colors.
    by thesame
    The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
    01-12-2024, 10:39 AM
  • DynaxSC
    Stubborn GIGABYTE B365M AORUS ELITE - main PCIe x16 GPU port working only in x8 width mode
    by DynaxSC
    I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
    I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
    Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
    Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
    05-04-2025, 12:08 PM
