Rca l46wd22
  • eradz
    • May 2010
    • 20
    Rca l46wd22
    Whats up ppl. I took my friends TV to the local repair shop(back before i actually started doing minor repairs myself) and let them see if they could repair it due to the cable not getting a signal. They fixed it and everything was good.
    Its been about 2 years since that issue and now its doing it again. So i bring it to my house and put it on the pool table. I do a little google searching before I pop it open. All the stuff I found pointed to a bad fuse on one of the boards.
    I open up the back and locat the fuse on the board and theres a strip of solder over the fuse... So this repair shop just bypassed the fuse to fix the issue. So I walked down to the repair shop, which have a horrible rep for being shaddy(didnt know this til now), and ask them about the TV which they some how cant find me in the system. I need to locate the bill from 2 years ago.
    I cant seem to locate any parts for this model online either. If anyone knows a good parts store online, please let me know
    Parts: PCB Main BD P810NA-D 2164949B 40-T21649-49B4XG
    part number is 274656
    Hopefully I can find the bill and go to the repair shop and make them repair this for free. Can post pics if needed!
    Thanks for all your help
  • digge
    • Apr 2006
    • 296
    Re: Rca l46wd22
    Sounds like a dodgy way to fix something. The fuse obviously blew for a reason.
    Try to get them to fix it, if not get back with pictures and someone here might be able to help you better.
    • corrize
      A funny fuse story – Lumix LX100 II
      by corrize
      Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
      I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
      The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
      There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
      And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
      10-19-2023, 09:58 AM
    • jesterace
      Samsung UE46ES8000 Blown fuse but no other signs of short
      by jesterace
      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
      09-11-2024, 03:14 PM
    • jshhh
      Help replacing fuse on my Mimaki CJV300-160 vinyl printer
      by jshhh
      Hi guys,
      I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
      How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
      Anybody know how to remove this type of fuse?
      (The fuse is toward the bottom of the image labeled F2)...
      06-17-2025, 01:35 AM
    • Babbar
      by Babbar
      04-12-2024, 01:12 AM
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
