polaroid flm-373b lcd power issue and fixed!
  • 8ballspecial
    • Nov 2014
    Re: polaroid flm-373b lcd power issue and fixed!
    Ok, Thank you! In this case it did. I hope the same trick works again. I found a caps kit on Amazon for that board, hopefully it is low ESR as it didn't specify...I do know they are heat rated.
    • BradHabit
      • Nov 2015
      My neighbor was throwing one of these out and I grabbed it after seeing this post. Upon speaking to him about it, it has this same issue currently and he stated that he had already sent it in once.
      After opening it up, I saw that the 2 suspect caps were replaced with Sanyo 1000uf/35v ones. They didn't even bother cleaning off the flux they used for the repair. I reflowed the two caps and cleaned them up really well to see if there would be a difference and unfortunately, no change.
      I am not getting any lights or any response from the unit, I am going to try to replace those two caps and see if that helps anything.
      It's nice to see that I am not the only one who really likes tinkering.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Nice one
        • TJVJR
          • Jul 2013
          • 25
          My Polaroid FLM373B now has no indicator lights whatsoever , I was wondering if you resolved you issue to see how to proceed with mine .
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • claws77
            lenovo flex 5 14itl05 power sequence issue
            by claws77
            hi guys, my motherboard will not start no matter what
            when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
            but rest nothing happens no sign of life.
            this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
            with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
            but now nothing happens no matter how much i wait/ charge/ press and hold power button.
            i have no knowledge of motherboards ....
            10-20-2024, 02:48 PM
          • yaya3gmax
            Laptop Power Issue – Works on Battery, Fails on Adapter Load
            by yaya3gmax
            Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
            Symptoms:
            • Laptop works normally on a pre-charged battery.
            • Battery does not charge when adapter is connected.
            • Without battery:
              • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
              • Speakers “pop” when power cut occurs indicating harsh sutdown.
              • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
            08-21-2025, 07:16 AM
