Polaroid TLX-03210B Repair (and introduction)
  • cbogg
    • May 2011
    I have a Polaroid tlx-03210b, that a week ago Saturday, decided to go up in smoke. Literally. A poof and some stink later, I had a worthless, or so I thought at a time, 32" paperweight.
    After some Googling, I discovered where to look for a fault, and subsequently, to this very forum. I decided that the two blown capacitors (one so much it popped the bottom, spewed the electrolyte, and left the one lead in the board) were cheap enough for me to attempt to fix.
    I did own a soldering gun after all, and had become somewhat adept at joining wires together, so I figured I'd give it a shot.
    I went online, found the caps I needed from Digi-Key. I chose these Panasonics because I figured, at the time (further research, on here, led me to believe I made the right choice) Panasonic was a name brand, and heck, these were the most expensive, 10uF 450v capacitors I could find with my limited knowledge.
    I ended up buying 4, figured I might screw one up (never soldered a board remember?), and a small roll of solder wick (this thing is gonna last me forever). My order total? A whopping $13.12 after tax and Priority Mail Shipping. "New" board, about $60 bucks. New TV, $350 plus. It was worth the gamble. Order placed Sunday, arrived Wednesday, Minnesota to Upstate NY, not bad.
    Fast forward to Wednesday, my package arrived! By this time I had bought a 30w iron (mine is a 100w gun, with a flat wide tip for wiring, I used it to remove the blown caps, but I knew this wasn't the right tool to get decent results going back in) for 5 bucks from walmart, and a small package of silver infused solder with flux from the big orange (was looking for tips for my old gun, figured while i was there...) another 5 bucks. Now we're up to $25, and of that most was sort of "optional". I proceed to tear into like a package on Christmas the year NES came out (turns out I didn't get one till the following year, dammit). I giddily take out the board, clean up the mess from the blown cap, which by the way took me longer to do than to take the tv apart in the first place, remove, and replace the blown caps, and put it back together, that garbage gets cooked on quick.
    Throw the thing back together, and voila! One working TV! One a side note, the slight, almost unnoticeable electronic "hum" it had since new, is now gone. Dead silent if you mute it. Also, I have noticed that the picture, once I dialed it back in, is 1000x better than it was before, this time with a cheaper box (finally put the DVR with my plasma, this one is now hooked to a standard box). Coincidence? Maybe.
    Been now running beautifully, for almost a week now, no hiccups at all.
    Actual total parts cost, for the two caps I used (not counting the spares), 2.08 plus 5 and change shipping. So, I kept this out of the scrap heap for a whole 8 bucks and a few minutes time.
    I'm now greedily hunting craigger's list for some non-working LCD's, PC's, and hopefully a G5 mac attack, just to play with, haven't found any yet locally though, thanks to this forum.
    THANK YOU BADCAPS! And to TC for starting this whole thing, hopefully will be buying a few kits from you in the future, those poly's have me intrigued......
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • swerg
    Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
    by swerg
    Hey everyone,
    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
    06-06-2024, 03:39 PM
  • MrzPdlch
    Blown fuses on Gigabyte GTX 980TI 6GB
    by MrzPdlch
    Hey everyone,
    I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
    Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
    Find some pictures of the actual GPU together with a picture of how it should look like.
    I also wonder whther it might be a problem that there...
    03-10-2024, 04:14 PM
  • cheeky2
    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
    by cheeky2
    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
    06-15-2025, 05:12 AM
