hi guys i have an LG 50pg60 the problem is that i was watching tv than it went off just like thatd and does not turn back on ,i unplug and plug it back ,did reverse polarity on outlet,i check the power cable to tv it is fine, and there is Noise Filter did my best checking it ,and check fuses ,can someone please help me what to do will appreciate ,
LG 50PG60 wont turn back on
Tags: None
Re: LG 50PG60 wont turn back on
hi guys how can i upload file JPG it keeps telling me that upload fail thanks in advance -
The max resolution is 2000x2000 and probably around 2MB for the JPG file size.
Some proper punctuation to break up your sentences so we can understand what you are saying without having to read it 3 times is also likely to get you some help. This isn't twitter.--- begin sig file ---
--- end sig file ---Comment
Hi guys i have a LG-50pg60 au the thing is my tv went off suddenly and than never came back ,i check one of the fuses ,one was burn out ,and i replace it and than ,i put back everything and plugged the power on ,and again the fuse burn out again ,i am sending some pictures i am sorry i did not post pictures before ,how can i test what is burning the fuse ,i will appreciate any guide to figure what can i replace any part hopefully you guys can determine with pictures what steps to take any additional info please contact me i will appreciate any help to determine if power supply board is good or not thanks in advance
hope this pictures will help thanks again
Assuming you have a meter, check for shorted components. First check from gound to the load side of the fuse. If it is grounded, then check the bridge rectifier and go from there. By the way, that is the black component with four leads in the first picture - bottom left cornerThe strong-minded rise to the challenge of their goals,the weak-minded BECOME HATERS
thanks for the reply i am sorry i am dummy i do have a meter with the pictures please guide i can do the fuse testing and the second part and on no clue thanks sorry body will appreciate your help thanks
freefixComment
1) In pic
https://www.badcaps.net/forum/attach...0&d=1305477971
you have a bloated cap.
2) In pic
https://www.badcaps.net/forum/attach...9&d=1305477948
the upper right one looks bloated too.
3) At MINIMUM, you will have to replace both. Since 2 are bloated, most here will probably recommend that you replace all the electrolytic caps with low ESR quality brand name caps.
4) For pictures, this is an example of what we want.
https://www.badcaps.net/forum/showpo...94&postcount=1
We want one clear shot of all the boards so we can see the relationship between each board. Then we want each board close up, but we want to see the entire board (not cropped).--- begin sig file ---
Hi i check with power on
fuse 101 = 120v
fuse 108= 58v
bridge rectifier second set of pins
+ vs -=0
+ vs s = 58v
+ vs s2=58
+ vs grd=0
second bridge same reading hope this help
Assuming you have a meter, check for shorted components. First check from gound to the load side of the fuse. If it is grounded, then check the bridge rectifier and go from there. By the way, that is the black component with four leads in the first picture - bottom left cornerComment
where can i get good caps please let me know i will appreciate that
freefixComment
is there brand that will hold more than the one the i have thanks
freefixComment
how can i check 5v or 19 v on my board i will appreciate that thanks in advance
freefixComment
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by chopduelHi,
I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:- TV would randomly turn off then back on.
- TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
- Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by JohnML1975Dear Forum members
I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
I will upload some photos and share my trouble shooting steps so far8 Photos -
This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 02:30 PM
- Loading...
