need the part number for q7 on the power suppy board fsp22-3f01
view sonic 3260w
Tags: None
Re: view sonic 3260w
"a major issue with these supplies is q7, a small surface mount npn transistor. When this puppy goes bad, the supply pulsates, meaning your +5v line may run from 4.0-5.9 and it oscillates back and forth. It also causes I believe c36 to fail as well. Replace this transistor, I use any reasonable npn transistor and u should be fine." -
Thanks I have subed a 2n222a and still have 5v . I also removed the zener d4 for testing and may have reinstalled it in reverse . After 75 years you start to do things like this can you give me the correct orintation of the diode ?Comment
Thanks I had it installed right . I noticed how you subsited the diode good idea when you cant find an smd .Comment
This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...09-07-2024, 02:50 AM
by ThefixinatorHey guys, I'm feeling like a noob trying to get flexbv to work to be able to download and view a particular board view of a mac mini 2018. Ive tried to read how to use the open board data but it's appearing to be a little confusing on how to actually look up a particular boardview. I'm using the free version to get my feet wet with the software. Ive checked to make sure under the program preferences the openboarddata.org is in the right spot which appeared to be there by default but im not able to open up and board preference to search for a specific board view. I'm probably confused on how it...
Channel: Schematics and Boardviews
by parmeshwarPleas share ASROCK Q370M Schematic and Board view if available
07-18-2025, 02:01 AM -
by magnehHello
Got this speaker from a friend , defective. Power led comes on and off , in a loop.
Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
Still, I need to replace this transistor.... -
by elsomerhi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...1 Photo
- Loading...
