Pleas share ASROCK Q370M Schematic and Board view if available
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Hello friends!
I have an ASRock Z690 PG Riptide motherboard (rev.1.02) that had some bent processor socket pins. After fixing them, when I turned on the board, a spark came from an SMD capacitor on the back of the board. It still turned on and worked, but there could be a problem. I would like to know if anyone has the boardview so I can know which capacitor this is and if there is any other defect on the motherboard.
Thank you in advance for your collaboration.-
07-29-2025, 07:56 AM -
by Nivla liuLooking for the board view or schematic for the ASRock x370 Killer SLI/ac, Board died, and I want to see if I can spot the fault and see if it could be repaired,
Thanks for looking, and if you have the file a big thanks.
Nivla-
- Loading...
