Panasoic TH-50PC77U blinks 7 times
  • hitomi
    Hi, I have a HDTV model TH-50PC77U and blinks 7times.
    As I researched, it means "SC Floating Voltage SOS" and it could be caused by SC, SU, SD, D or P board failure.
    I found a Troubleshooting book for TH-50PZ (http://www.scribd.com/doc/46124232/T...11DU-Chasisbut) but no luck for my model.
    Can anyone give me tips?
    Thank you.
  • rayrod81
    • Oct 2010
    • 205
    Re: Panasoic TH-50PC77U blinks 7 times
    7 blinks means a bad SC board or buffers most of the time on this generation of panasonics. The 2 I have seen recently had the 7 blinks. One had a bad SC or Y-sustain and the other had a bad lower buffer.
    • cadiman
      • Mar 2010
      • 397
      I don`t see any power supplies on ebay (CLUE).
      You might want to check mosfets after bridge rectifier (110vac in ). I have seen these fail on panasonic.
      Also on secondary of power supply see if you have 3300uf 85v caps (2) These fail.
      Some will be bloated and some will not. Power supply will shut down in either case.
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • brithepi2k
        Samsung UE75TU7020k No picture, Standby blinks 2 times
        by brithepi2k
        My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
        04-23-2025, 10:05 AM
      • mecha1166
        XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
        by mecha1166
        I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
        07-01-2024, 05:47 PM
      • magneh
        TX-65FZ800E - blinks 2 times red led no power
        by magneh
        Hi there
        I have this set with no power, blinks power led twice.
        This seems to point out to D board issue
        My first question is which one is the D board?
        The main board?
        Or one of the power boards?
        Are they labeled with this? (did not checked the boards yet)
        Thanks for any inputs...
        08-23-2023, 09:02 AM
      • Awejire
        HP EliteBook 820 G3 blinks five times
        by Awejire
        I have this HP EliteBook 820 G3 with board number 6050A2892301-mb-A01 that blinks caps lock five times when powered on and i have tested it some other known working RAM and discharge the BIOS by shorting the two pins but still same and I'm thinking if it could be currupt bios chip
        07-16-2022, 10:30 AM
