HP PL4260N (LG PD42X32002 Panel) Help Please
  • itek
    • Aug 2010
    • 65
    Hi guys, my first post here looking for some help. I have an HP PL4260N that came in with no video & working sound. It had a blown fuse on the Z-Sus board so I replaced STK 795-820 ipm on Z-Sus, still no video. I replaced the STK 795-820 ipm on Y-Sys (which had blown), and when powered blew the fuse on Z-Sus again. After the fuse blew I get a very dark static around the edges, and the Y-Sus heatsink gets very hot. If I put a good fuse in the Z-Sus board, it doesn't blow again but the unit doesn't even power up, it clicks, thens clicks back red. Where to I go next? I thank you in advance for any help, I'm still learning!
  • itek
    • Aug 2010
    • 65
    Re: HP PL4260N (LG PD42X32002 Panel) Help Please
    OK so these 2 large caps on the power board are Nichicon 450V 330uf. They both are testing ~300uf and last night after desoldering 1 pin to remove them from circuit they were testing ~.17-.23 ESR now this morning they are testing ~.30-.34 ESR. Is this normal or are they toast? Thanks!
    • PlainBill
      • Feb 2009
      • 7034
      That is normal. These are not low ESR caps.
      PlainBill
      • itek
        • Aug 2010
        • 65
        Wow almost 2 months later I got it running!!!!
        1. Replaced IPM on Z-Sus,
        2. then blew it with a bad Y-Sus,
        3. then replace IPM on Y-Sus,
        4. then replace Z-Sus board
        I read in a post once here, I forget who posted it "If you want to learn, replace the chip, if you want to fix it, replace the board" - Excellent Advice! I have learned alot
        Its running now but I got light red static, I guess I need to calibrate it..
        Thanks everyone on this forum for being so helpful.
        • itek
          • Aug 2010
          • 65
          OK I adjusted in accordance to the LG guide with no luck....... I guess I'm stuck with the red snow without a firmware flash from what I hear?
          • rayrod81
            • Oct 2010
            • 205
            Yeah to get rid if the red maldischarge you would need to update firmware on the control board.
            • cadiman
              • Mar 2010
              • 397
              That would have been me. ( If you want to learn).
              Good for you to take the long road!
              Cadiman
              • kordris
                • Feb 2012
                itek maybe you can give me some tips on getting my model to working. I had the same problem with the red light. Also on those caps I'd they are bulging very very little on the top could they be bad? If anyone has a idea on what could be the problem. Thanks for any help.
                • corrize
                  A funny fuse story – Lumix LX100 II
                  by corrize
                  Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                  I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                  The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                  There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                  And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                  10-19-2023, 09:58 AM
                • howardc64
                  LG 49UJ6500 LCD panel lighter band that goes away
                  by howardc64
                  49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                  Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                  02-19-2023, 12:13 AM
                • triplefour
                  SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                  by triplefour
                  TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                  tcon is built into mainboard.
                  Only one cable goes to panel boards.
                  there is a cable from one panel board to the other that links them.
                  cost cutting measure that results in us having harder time to diagnose.
                  removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                  used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                  07-28-2022, 07:59 PM
                • Storyteller12
                  QN55Q60R Service Menu Panel Help
                  by Storyteller12
                  I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                  I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                  I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                  the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                  01-13-2024, 01:57 PM
                • maneatingmonkey
                  Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                  by maneatingmonkey
                  I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                  There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                  03-27-2024, 07:17 AM
