Diagnose plz: Sony KDL-46V4000,Tearing or Dark, Sound OK
  • schitthoch2
    • Mar 2011
    • 4
    Hi there.
    Our KDL-46V4000 has a picture problem which we would like to fix. But as we are real electronics novices, we need your expertise.
    When we turn on the TV the symptoms are:
    • There is ALWAYS sound
    • Usually there is tearing in the picture on the right side
    • Flexing the TV on the right side leads to either a good picture or dark screen with backlight on
    • If the screen is dark, turning off and on again gives more tries until picture is good.
    • This worked for about 3 months
    • Since recently, the picture stays dark (backlight ok) more often right after turning on or after flexing
    • Also, we need about 20 tries of flexing until we get a good picture
    We have read posts regarding Sony TVs here before posting. We have seen talks about replacing TCons or Fuses as well as checking connectors from the screen to the Tcon.
    What would you advise us to do. So far we did not open the bugger.
    Help appreciated.
    Best regards
  • PlainBill
    • Feb 2009
    • 7034
    Re: Diagnose plz: Sony KDL-46V4000,Tearing or Dark, Sound OK
    Originally posted by schitthoch2
    Hi there.
    Help appreciated.
    Best regards
    Many of these sets had bad connections between teh ribbon cables and the panel. Tcons are also a problem. If the symptoms you describe are consistent with a bad connection; flexing is unlikely to cure a tcon problem.
    I haven't tried this, there is no promise that this will help. Others have reported some success with wedging a dense foam between the bezel and the panel. I'd suggest reading other recent threads here on Sony TVs, then deciding if you have the mechanical skills to try this.
    PlainBill
    • schitthoch2
      • Mar 2011
      • 4
      [...] If the symptoms you describe are consistent with a bad connection [...].
      Hi PlainBill
      Thank you for replying. You confirmed our thoughts that the Tcon might be OK.
      But as we understand you suggested two possible fixes. The second is the foam, but what is the first one ? Mechanical skills should be no problem.
      Also, are there any pictures of the suggested "foam repair" somewhere?
      Thank you very much.
      • schitthoch2
        • Mar 2011
        • 4
        The diagnosed problem can be narrowed to the following with high probability:
        http://www.avsforum.com/avs-vb/showp...4&postcount=29
        So my question is now if the bumpons mentioned need to be heat resistent and if the connectors are under high voltage or not!
        • PlainBill
          • Feb 2009
          • 7034
          Heat resistant would be good in that you don't want a material that softens when it gets warm. The highest voltage in the area would be less than 20 volts; the material should be non-conductive but a high breakdown voltage is unnecessary.
          PlainBill
          • schitthoch2
            • Mar 2011
            • 4
            I could partly fix the TV with some Bumpons and the way described in my previous post.
            Partly, because I should have tried this a lot earlier. All the flexing seems to have damaged the connectors too much.
            I now could reduce the issues to around 20 percent of switch on's.
            Replacing the connectors ( and the LCD) is no option.
            key learnings: Fix it before flexing too heavily / often. No rocket science.
            thank you PlainBill
            • iglitare
              by iglitare
              09-04-2025, 07:13 AM
            • DKWS89
              Sony XBR 49x900E - Sound and backlight on but no picture
              by DKWS89
              Hey Guys,
              So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
              All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
              12-14-2023, 04:30 PM
            • KYBOSH
              Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
              by KYBOSH
              Previous owner said TV just went blank one day.
              They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
              Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
              The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
              There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
              I just downloaded the Sony KD-75X7800F Service Manual and...
              11-19-2024, 10:12 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
