RCA P52929 Dead
  • maybenever
    • 158
    RCA P52929 Dead
    This TV was connected to a sat. receiver. It was on channel 3, then it started going thru the channels, like a search. It then powered it's self off. Would not power back on.
    A few hours later, It powered back up and worked fine for several days, then same thing happened, only now it will not power on at all.
    I've checked the main power fuse, it's OK. I can see a resistor on the board that looks bad. (I marked it on the pic), but I can't get the board all the way out because of the other part I've marked. (don't know for sure what it is).
    Does this look like something for a DIYer should attempt?
    Thanks for all input
  • PlainBill
    • Feb 2009
    • 7034
    Re: RCA P52929 Dead
    It depends on the DIYer. Some barely know which end of a screwdriver to hold, others could diagnose the problem and suggest an improved design before they got the chassis out.
    Seriously, it depends on your tools. Looking for obviously discolored or damaged components is a valid troubleshooting approach. Replacing components because they 'look bad' without first confirming they are in fact bad is unlikely to be successful.
    Do you have a DMM and know how to use it? Can you detect a shorted transistor? Do you have good soldering skills? If the answers to all three questions are 'No', I'd suggest you don't have the skills to fix this.
    To cover two of the issues, the proper technique is to stand the chassis on it's side to work on it. And the part preventing you from removing the chassis is called the flyback.
    PlainBill
    • maybenever
      • 158
      Re: RCA P52929 Dead
      never checked a transistor, but yes to the other two.
      I've repaired a Tv, dvd player, and a settop box.
      • PlainBill
        • Feb 2009
        • 7034
        Re: RCA P52929 Dead
        Give it a go. Perhaps someone can direct you to a service manual; I just drew a blank at my usual source.
        PlainBill
        • maybenever
          • 158
          Re: RCA P52929 Dead
          I found a service manual (chassis PTK195S1B), but it's the hardest schematic I ever tried to figure out.
          • PlainBill
            • Feb 2009
            • 7034
            Re: RCA P52929 Dead
            I've never worked on a CRT projection this complex, but it's simpler than a plasma TV. I work from the power supply. This should have a main and standby supply. The standby is always on. If it isn't, figure out why. If it is, figure out why the man supply doesn't come up.
            PlainBill
            • maybenever
              • 158
              Re: RCA P52929 Dead
              Thanks for the starting point. Are the wires at the other end of this flyback removeable? This chuck of wood and PCBs is sitting in my niece's bedroom. I'ld like to bring those boards home to check em out. If not I'll start checking em there.
              Thanks Again
              • PlainBill
                • Feb 2009
                • 7034
                Re: RCA P52929 Dead
                Thanks Again
                I'm not sure. Perhaps one of the guys who regularly work on these could help you.
                PlainBill
                • f67bird
                  Technician
                  • Apr 2007
                  • 57
                  Re: RCA P52929 Dead
                  Yes, they are removable. There are 3 wires that you will need to disconnect that go to the front side of the box. The thick red one is the high voltage lead...it goes into the high voltage splitter. Follow it up to the splitter, pull back the small rubber boot that seals the wire going into the splitter, the lead then pulls straight out...but it sometimes takes a good tug to get it out. I usually use long nose pliers and hold both hands together and give a short tug...carefull not to hit the crt neckboards when pulling the lead towards them.
                  The smaller wire coming out of the flyback goes to the back side of the focus/screen assembly usually mounted in the front of the box, that one should come out easily. It has a larger rubber boot around it that you should try to pull back first.
                  Then there is a white ground wire that goes to the grounding terminal block near the high voltage splitter. Follow it to the front and remove it from the grounding block, it will most likely have a small tab that you will have to press in order to get it to release.
                  I would also take a few photos of the other connectors that go over to the other board before removing them.
                  Learner
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    Re: RCA P52929 Dead
                    just pull the whole lightbox assy.the complete works just slides out.
                    btw the last 195 box i saw that acted like that had a crt coolant leak.
                    • maybenever
                      • 158
                      Re: RCA P52929 Dead
                      Thank all for the info. I didn't see any leakage signs anywhere. After I got all the dust bunnies out, it looked OK. It'll be the weekend before I can do somemore checking.
                      • maybenever
                        • 158
                        Re: RCA P52929 Dead
                        Well, between NCAA games, I got back into this TV this weekend. (Sorry about your AZ Wildcats PlainBill ) I've decided it's too compex for me. I couldn't get the plasic tray off the bottom of the PCB to do some voltage checking. It's a really bad spot to work, If she can get some help, she'll bring the thing to my shop. It's 12 years old, probably not whort the cost of repair parts. Thanks for all the input.
                        • Wizard
                          • Mar 2008
                          • 2296
                          Re: RCA P52929 Dead
                          This was our butter and bread chassis. Channels and TV acting weird and I do see smoker's gunk is surefire bad tact buttons. Go straight to the front end. Pull the speaker grille by the edges all around, just firm pull. Then undo the screws for the buttons, then replace the tact switches (all of them). Try again and see if this fixes the problem. Very common especially with smokers.
                          There is very little to go wrong with chassis but I want you to leave these boards alone and fix the front buttons first. Spraying it with cleaner will not fix.
                          Cheers, Wizard
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Re: RCA P52929 Dead
                            Not my team. Unfortunately, the Gophers didn't come close to doing well enough in the regular season to get considered for an invite. But pro Baseball starts this week and I can look forward to the Twins making a statement.
                            PlainBill
                            • f67bird
                              Technician
                              • Apr 2007
                              • 57
                              Re: RCA P52929 Dead
                              I am not disagreeing with anyone, but I know you may not have a bunch of the correct type of new switches on hand.
                              You can see if the switches are causing your problem first if you want to by unplugging the large wire connector on the top of the box (where the three lenses are)
                              If you unplug that the front switches will no longer be connected, but you can still operate the set with the remote control. If the set still acts up, its not the switches causing this.
                              Once you get the set going, it's a good idea to replace the switches though...they can cause this and other strange things.
                              Learner
                              • maybenever
                                • 158
                                Re: RCA P52929 Dead
                                Thanks f67bird, that sounds doable. I'll give it another go, There are two smokers in the house.
                                • double_DD
                                  How can I be sure that my EC chip is dead?
                                  by double_DD
                                  As the title suggests, how can I be sure that my EC chip is really dead?
                                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                  03-12-2025, 07:47 AM
                                • cappernicus
                                  Acer Spin 5 - Lenny_ICL (19771-1) -- Dead - PM_SLP_S3# held low
                                  by cappernicus
                                  Laptop model: Sp513-54n-74V2
                                  Testing power rails (separated by chip) reveals:
                                  19V_DCBATOUT - (active)
                                  5V_AUX_S5 - (active)
                                  5V_S5 - (active)
                                  3D3V_AUX_S5 - (active)
                                  3D3V_S5 27Ω - (good) - enabled by Nuvoton chip
                                  1D8V_VCCIN_AUX - (good) - enabled by 1D8V_S5 PG signal -- (dependent on 3D3V_S5)
                                  1D8V_S5 41Ω - (good) - enabled by 3D3V_S5 PG signal
                                  1D05V_VNN_BYPASS - (good) - enabled by 1D8V_VCCIN_AUX PG signal...
                                  09-25-2024, 05:19 PM
                                • thstuff
                                  Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                  by thstuff
                                  A) TV initially dead
                                  B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                  C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                  D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                  E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                  12-26-2024, 09:10 PM
                                • disorder
                                  ps5 edm-033 dead after hdmi/usb ports destroyed
                                  by disorder
                                  hello guys,
                                  i need help to repair a edm-033 ps2
                                  history : as always hdmi port and usb ports destroyed after unplugged
                                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                  so i changed it
                                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                  i don't see any projection of liquid metal on pcb.
                                  01-14-2025, 12:48 PM
                                • zunasthegreat
                                  Chieftec GPS-450-AA with dead 20N60C3
                                  by zunasthegreat
                                  Hello everyone hope all doing well!
                                  I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                  09-01-2024, 07:12 PM
