Re: Trutech PLV16190 picked off a trash pile
Every multimeter, even the cheapest, gives a reading. How you interpret it is key.
If you have a manual ranging multimeter, set it to 200 (two hundred) ohms. Touch the black and red probe together. It should read 0.3 or 0.4 ohms. If it is higher than 1.0 ohm, there is something wrong with your multimeter.
If your multimeter reads "1" or "OL", it means the measurement is outside your chosen range. Don't confuse "1" on the left hand side of this display with 1.0 on the right hand side. The first means out of range and the second means 1.0 unit of your measurement.
A "1" of the left hand side means the component is > 200 ohms. That is, the bridge rectifier is not shorted.
