L/G AU-OPTRONICS panel
  • cadiman
    • Mar 2010
    • 397
    I picked up this 42lg30-ua no backlight. I found a bad mosfet on the slave inverter. Took care of that and had a bad buzz and very short backlight. I then pulled the panel apart and found alot of the tubes near the end of their life (darkend in spots).
    This is the second au-optronics panel I have not had much luck with.
    Should I be hunting down new tubes for this panel or just find another l/g with same panel/broken screen?
  • jetadm123
    • 2169
    Re: L/G AU-OPTRONICS panel
    I think you already answered your own question. Since this the second AU panel you've had problems with, waiting around for another AU panel may be inviting trouble. Try ccflwarehouse.com for some new tubes. Several members have had a good experience with them.
    • ecking767
      • Oct 2009
      • 492
      A 42" LCD TV still have value in my opinion, I wouldn't buy any used CCFL tubes unless I get them very cheap or close to nothing. Here is a seller on eBay offering the CCFL tubes you need. I see the seller will accept an best offer. Make an offer !!!
      http://cgi.ebay.com/LG-42LG2100-42LG...07386371776233
      • cadiman
        • Mar 2010
        • 397
        Thanks for the input I`ll check it out.
        • mbates14
          • May 2005
          • 169
          i save the tubes from all the cracked LCD TVs i get before i scrap them.
          I got maybe 2 mailing tubes FULL of them.
          I had enough to re-tube a sharp Aquos LC37D44U awhile back. it played 24/7 for 2 years streight. killed the tubes.
          • cadiman
            • Mar 2010
            • 397
            I do have a Sharp Aquos 42 with a broken panel somewhere in my back building. I guess I could check it out.
            That sounds like my mom`s tv. She burnes out tvs and coffee pots.
            Thanks for the reminder!
            • cadiman
              • Mar 2010
              • 397
              I found a low hour panel (broken) and removed all the ccfl tubes (18) and soldered them into the optronics panel. the panel lights up and stays lit. Also no more buzzing sound from inverters.
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • triplefour
                SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                by triplefour
                TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                tcon is built into mainboard.
                Only one cable goes to panel boards.
                there is a cable from one panel board to the other that links them.
                cost cutting measure that results in us having harder time to diagnose.
                removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                07-28-2022, 07:59 PM
              • Storyteller12
                QN55Q60R Service Menu Panel Help
                by Storyteller12
                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                01-13-2024, 01:57 PM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
