Samsung Hlp5063w problems
  • rubicondsrv
    • Nov 2010
    • 39
    I sold an HLP5063 a few weeks back after replacing the lamp.
    customer called today, and said it turns on then flashes the timer lamp and shuts off, and if cycled on and off 3 times all three lights on the front flash.
    customer also says by unplugging and repluging the tv it somtimes will come on for awhile.
    I have the service manual, but it dosent describe anything like this issue, I will be going to the customer tommorow, and would like to have an idea of what to check.
  • rubicondsrv
    • Nov 2010
    • 39
    Re: Samsung Hlp5063w problems
    went and looked at the unit, the timer light donent flash, the lamp light flashes like the unit is starting, then it resets 3 times and flashes all three lamps.
    power supply was deleviring cprrect voltage to balaast, but balast wasnt powering the lamp, also color wheel wasnt spinning up.
    when I was probing the balast board the color wheel spun up.
    Is this a color wheel problem or is it a ballast problem?
    • mbates14
      • May 2005
      • 169
      color wheel. KNOWN issue.
      • rubicondsrv
        • Nov 2010
        • 39
        thanks
        • rubicondsrv
          • Nov 2010
          • 39
          ok, replaced color wheel, it was working and customer was happy.
          then got call from customer saying it worked for a few days, now takes 30 minutes of unplugging and replugging to get it to come on and he demands his money back.
          I told him to sell the tv on cragslist and I will refund him the difference (i dont want it back not knowing what he has done to it), but I am stumped as to how this problem occurred when it was working when i left.
          best I can figure is dirty power, or a defective customer...
          • PlainBill
            • Feb 2009
            • 7034
            This sounds like a case of 'You touched my TV and now it's not working, so it's your fault'.
            PlainBill
              09-07-2024, 05:50 AM
            • AJ847.63e
              BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
              by AJ847.63e
              Hi All.
              Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
              The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
              09-18-2023, 06:42 PM
              09-06-2024, 11:40 PM
              09-06-2024, 08:40 PM
