LG 50PC3D-UD power issue
+ More Options
Posts
  • nswizdum
    • Jan 2011
    • 18
    I recently picked up a LG 50PC3D-UD to repair. When I power the TV on, I hear the relays click, the green led on the front blinks 3 times and then goes back to red. I tried searching around a bit and found that these units have issues with the 10v 3300uf caps on the power board. All the caps look fine to me, no obvious bulging or leaking, but I replaced them anyway. The TV still wont power on fully. I found some LEDs that look like they may be error codes, and I included a picture of them. I also noticed a green and red LED under the shield on the tuner. I also tested all the pins on the p801,802, and 803 connectors. All the voltages were fine, except for the 3.3v pins, there was never any power on those pins.
    Not sure if its a problem or not, but the two green thermistors next to the 2 black relays on the power board are closed at room temperature. This means that they are shorting the two load pins on one of the relays which seems like odd behavior to me, but it may serve a purpose I am not aware of.
    I found what appears to be a service manual, but I am not sure how to follow it to diagnose these problems.
    http://www.scribd.com/doc/7580885/LG...raining-Manual
    Has anyone here worked on these sets before? I'm new to the world of plasmas and I don't really know where to proceed from here.
    The pictures are too big to upload here, so I put them on google Picasa:
    http://picasaweb.google.com/joshuabu...eat=directlink
    Thanks in advance,
  • PlainBill
    • Feb 2009
    • 7034
    Re: LG 50PC3D-UD power issue
    The 3300uF, 10V cap problem is for Philips plasmas and otehrs using a Samsung panel. LG electronics makes their own panels, so that bit of wisdom doesn't apply here.
    I'm drawing a blank on a service manual for this TV. Perhaps you can find a cross reference here.
    Either use software to reduce the size of the pictures or reduce the resolution of your camera. Remember, use 'Manage Attachments (below the text entry area), do not post pictures inline.
    Because of past problems, I refuse to load pictures stored offsite.
    On the back of the plasma panel there should be a white label that starts with PDP50. What is the full model number of that panel.
    PlainBill
    • cadiman
      • Mar 2010
      • 397
      It looks like these use ipms. You may have a bad y drive board and that would shut down the power supply. I am not sure about about this model but most of the one`s I have worked on you can unplug the y or z board and power up the tv and see if the power supply stays up and runs. Try and search old posts you might find the info you are looking for.
      • nswizdum
        • Jan 2011
        • 18
        Thanks for the replies. I understand the problem with off-site pictures, I figured Google would be fairly trustworthy. I'll try to find a way to shrink them down.
        I did hear about unplugging the y or z board, and I just tried it after posting this. I still had the same problem when unplugging all 3 cables, and when unplugging each one separately.
        The full model number is PDP50X30010.DDDRBAB
        I will edit this post and add in the attached pictures (if that is permitted on this forum) or I will post them in a few minutes.
        • nswizdum
          • Jan 2011
          • 18
          Here's the pictures. I included some of the surrounding boards too. Where do I find the Chassis number on the panel? I get no service manuals for PDP50X30010.
          • PlainBill
            • Feb 2009
            • 7034
            I envy you. The LG 50PC3D chassis uses the same panel as the LG 50PC1D chassis. I believe this file was obtained from Scribd; Elektrotanya's server is down this morning.
            What you want is 16077007-LG-50PC1DRTroubleshootingManual-2007-VG-Training.pdf
            This manual goes into exquisite detail on troubleshooting the entire chassis, including the panel, power supply, sustain and main control cards. It also contains information on the hard drive.
            Incidentally, I prefer to see an over-all shot of the back of the TV as one of the pictures. That puts the rest of them in perspective.
            PlainBill
            • nswizdum
              • Jan 2011
              • 18
              That service manual looks like its going to be immensely useful, although my TV doesn't have a hard drive in it.
              Here's a shot of the back panel.
              • nswizdum
                • Jan 2011
                • 18
                Ok, I just double checked all the pins for the 800,802, and 803 connectors. All the voltages except 3.3v are still fine, and I do have 5v standby when the tv is plugged in. I'm going to wait for any residual charge to dissipate then check the mosfets in the "HS6" section of the power supply board.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Yah, no 3.3V would cause problems.
                  PlainBill
                  • nswizdum
                    • Jan 2011
                    • 18
                    Scratch that, I can measure 3.3v when all cables are plugged in, it must come from one of the attached boards. Any ideas on where to proceed from here?
                    I should also specify that when I said all the voltages on the pins were good, I was only referring to the ones that were labled. The VS-ON pin never shows a voltage.
                    • nswizdum
                      • Jan 2011
                      • 18
                      Looking at the service manual, I realized that VS-ON comes from the digital board, so it would read 0v with the cable disconnected. I re-attached all the cables and tested the VA and VS pins (I am going through the "power sequence" listed in the manual to try to find where it is stopping, since I can hear the relays click, and can read 3.3V, 5V, 6V, 12V, and 19V, I know it is making it to step 3). I read 0v on VS, and VA gets to 5v before the tv turns off.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        That goes back to cadiman's comments. On some LG plasma TVs you can troubleshooting by disconnecting Y and Z sustain boards. On others you will still get a failure when you disconnect the Y-Sustain board - it detects the disconnected cable as an error.
                        As I recall, the training manual has information on troubleshooting the IPMs.
                        PlainBill
                        • nswizdum
                          • Jan 2011
                          • 18
                          The VS and VA voltages are generated on the power board though, correct? So wouldn't the problem still be located there, and not in the IPM module? Or could the IPM module be causing the failure once it starts receiving power from the VA source(the 5v it gets up to before the tv shuts back off)?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Correct. The blown IPM overloads the power supply, which shuts down to protect itself.
                            PlainBill
                            • nswizdum
                              • Jan 2011
                              • 18
                              I pulled the YSUS board and tested the IPMs as it was described in the manual, I think. I put my meter in diode test mode and tested all the pins in the order listed, there was a decent amount of resistance between all of them, no open or shorted circuits. I also checked over the caps and mosfets for any obvious signs, didn't find anything. I'm going to look around a bit more then move on to the ZSUS board.
                              • nswizdum
                                • Jan 2011
                                • 18
                                Also, page 59 of the troubleshooting manual states that when the YSUS board is disconnected from the power board, there will be "no display". Would that mean that the power supply should still function with that cable disconnected?
                                Sorry for the multiple posts, I keep missing the window for editing.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Yes, it does. The training manual for an earlier series of LG Plasma TVs was very clear that testing the Y-Sus by disconnecting the power cable from the Y-sus was not possible. This would be treated as a failure and cause the power supply to shut down. This sounds like they have updated the design.
                                  PlainBill
                                  • nswizdum
                                    • Jan 2011
                                    • 18
                                    PlainBill
                                    So now the question is, which design do I have? This is getting interesting.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Well, given that your training manual DOES mention disconnecting the power to the Y-sus, I'd believe the tests indicate your problem is not with the Y-sustain. Other than the exception mentioned above, the power supply outputs should be good if all sustain boards are disconnected.
                                      PlainBill
                                      • nswizdum
                                        • Jan 2011
                                        • 18
                                        I took another look at the power board and found a component that may be the problem. It looks like a large voltage regulator or mosfet, it's labeled Q855 on the schematic (it connects directly to the transformer that generates the VS voltage). It shows less than 15ohms resistance between each pin, in both directions, which is different from the other similarly labeled components. Theres also a box capacitor next to it that is caved in on the sides.
                                        The part is labeled "SD20N60" and "GAV602" on the front. I'm going to head over to my local parts supplier tomorrow and see if he can find a replacement. The store sells mostly NTE parts, for future reference, are NTE caps generally of good quality?
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
