Dell W3706MC - P/S or Video Controller
  • alycobaba
    • Jan 2011
    • 5
    So far, not so good. The television is a Dell W3706MC who's image is beyond snowy/noisy.
    Symptoms:
    - After being unplugged for several hours, it takes a very long time to turn on
    - Once on, it will random turn off after a short period of time... usually takes 2 or 3 times of turning off and on for it to finally be on and stay on
    - screen image (no matter the source- including menus) is degraded
    - upon first displaying an image/menu, it is somewhat readable but after a half second it becomes significantly worse ... change image/menu again, it is somewhat readable then becomes worse again after a half second ....etc.
    Maybe a bad power supply? Maybe a bad main controller? I really did look over all the caps and see no sign of any visually bad ones. Anyone have any insight into these symptoms? My first guess was controller board but the hard time starting up and random turning off for the first couple times makes me thing power related. Hopefully it's a P/S issue because for the life of me I can not find a replacement controller module for this silly thing! Appreciated!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell W3706MC - P/S or Video Controller
    Can you post clear focused top down view pictures of all your boards including an "overall" one?
    --- begin sig file ---
    --- end sig file ---
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • PacoGT
      Gpu DELL OEM RTX3080 No video
      by PacoGT
      Hello friends, I have a question. They brought me this video card, a DELL RTX 3080. They told me that it fell and the impact no longer produced video.
      When trying it, it's as if it wanted to give video but in the end nothing, I already checked voltages etc. everything is as it should, but without video
      I suppose it could be a bios problem but since sometimes they don't tell you everything, I've searched for the bios everywhere but without success
      I can't find a backup or something to try to reprogram bios and see if it's the fault, could you help me maybe someone has one that...
      02-18-2025, 01:08 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • huzo
      Dell 5590 no image on LCD,HDMI works ,the board works...
      by huzo
      The board is LA-F411P ,DELL 5590 ...
      The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
      02-16-2025, 03:08 PM
    • NotEnough
      Seeking Dell G15 Motherboard ICs for Embedded LED Controller (UEL1 and UEL2)
      by NotEnough
      I'm working on a repair for my Dell G15 motherboard (model GDL5L) and need two specific ICs to restore the functionality of the Embedded LED Controller (ELC). The missing components are labeled as UEL1 and UEL2 in the schematic, and they're both critical for LED control and system signaling. Here are the details:
      1. UEL1
      • Part Number: SA0000AWJ70
      • Model: STM32F070CBT6TR_LQFP48_7X7
      • Function: This microcontroller manages system signaling, power management, and SPI...
      10-28-2024, 01:44 PM
