Acer AT3201W color problem
  • fastvideo
    • Dec 2008
    • 55
    Start up screen good.
    Blue screen with no signal screen good.
    Input any video source look like a weak picture tube's image on a LCD tv.
    Power supply's cap look ok.
    What else could cause problem like this?
  • crepiduse
    • Nov 2010
    • 69
    Re: Acer AT3201W color problem
    One question, have you adjusted it from "warm" to cool? any difference? is this on all sources or just one?
    • mockingbird
      • Dec 2008
      • 5484
      The problem is the caps.
      Please list what brand, series, value and diameter and someone may advise you what to replace them with.
      • fastvideo
        • Dec 2008
        • 55
        All sources, and check with different video settings, no good.
        Rubicon caps on power supply is good.
        and the caps on the main logic board also looks good, but using Tempo caps.
        • crepiduse
          • Nov 2010
          • 69
          Replace the caps.
          • fastvideo
            • Dec 2008
            • 55
            I got a second main board, (with a different type lcd panel) put it up and the color comes back. But the image is off center.
            Swap eprom U33 24LC32A between the 2 board would got the image like the first post and the image like this post.
            Not bad capacitor in this case.
            Anyone here can send me an image of this eprom or can help to re-program this eprom?
            • Grape
              • Aug 2009
              I have this TV which CAN display a perfect picture, but it's brain is shot and can't remember the settings:
              The problem is the U33 eeprom (24LC32A) which apparently writes once per second and is guaranteed for 1 million writes - that's only 277 hours of 'on time' which is a HUGE DESIGN FLAW in the firmware. Supposedly there is an updated 'fixed' f/w, but I can't find it...
              The factory menus can be accessed by pressing the [VOL -] and [CH +] buttons simultaneously, and the colour gains and biases (see below) can be altered. But the TV does not remember them because the eeprom is toast.
              I may just replace the eeprom, it's surface mount so a very difficult and precise task. I don't know if it needs to be programmed? In hacking around with the factory menus I noticed a 'ghosted' menu that had an 'update' selection. This ghost menu was displayed as a random bug and didn't function properly - and I'm not even sure how it came to be displayed. I was just pressing buttons randomly trying to see what was up. The s/w and f/w in this TV is crudely written crap.
              If there is a USB port on the tv I will see if a computer can access anything in the TV.
              I contacted ACER for new f/w binary and how to install it, so far NO RESPONSE, of course...
              factory menu colour gains and biases:
              Typical settings (to get a good picture)
              R gain: 434
              G gain: 482
              B gain: 484
              R bias: 270
              G bias: 270
              B bias: 264
                Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) Spin 512 Specification for Upgrade or Repair
                This specification for the Acer Chromebook 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB boardview and 12" HD+ screen, Intel Celeron, 4GB RAM, 32GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                09-06-2024, 04:40 PM
              • String2016
                Acer Predator PH315-52 no display/black screen problem - need working bios please.
                by String2016
                I need a working bios on this acer predator
                MODEL:ACER PREDATOR PH315-52 54KC
                S/N:NHQ54SP00A024028992600
                SNID:02401039326
                Attached is the original bios no display problem black screen keyboard lights on...
                10-10-2023, 06:00 PM
              • mmccomputer
                problem with replacing lcd screen
                by mmccomputer
                I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                If anyone has any information on the subject...
                12-15-2024, 03:44 PM
              • Stuki
                acer aspire 3 A315-41g Screen Problem
                by Stuki
                Hi tech-guys,
                I have problem with Acer Aspire 3 (A315-41). When I pressing power button, the screen showing me this picture.
                Sometimes lcd screen works normally.
                Thanks advance....
                12-18-2022, 04:13 AM
              • Chrissygizmo
                Sony KD-55XG9505 lines on screen problem
                by Chrissygizmo
                Hello again everyone,
                This is my latest mission, to try getting this Sony tv back to normal working order…
                I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                02-19-2025, 11:31 AM
