Failue in this Power Supply for Westinghouse LCD . No apparent Bulging Caps, but that does not say one could cause LCD not to turn on.
Power supply made by DPS-210EP-2C
Tags: None
Re: Power supply made by DPS-210EP-2C
dps= delta made. delta makes very good power supplies, they are one of the best.
check the logic board of the tv... westinghouse is known for bad caps on the logic board.sigpic
(Insert witty quote here) -
Delta do use LTEC caps on their PSUs sometimes. They aren't as bad as Fuhjyyu but they do fail, especially in monitors where there is no fan to cool them.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Thankyou for this Heads up. I found a new Power supply, but I have not tried to find a Bad Cap on old Board. I will check Logic Board. Set does not belong to me, and I have not been able to find a Service Manual.Comment
I am considering replacing the VX2835wm's PSM217-404-H-R power supply with the DPS-210EP.
-Is the 12V connector the 2-pin connector that connects the power cable plug to the power supply?
-Does the 12V connector from the vx2835wm still fit even though it is slightly different or does the plug need to be replaced as well as the power suplly?Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by dragon3xHi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
that is still quite new, as it worked OK for some months until it failed.
At the time I was not into power supply electronics; it was put
aside and a new power supply installed inside the computer. Also at the time
power supplies were half the price of today's.
On the PCB there are a D339 and 7500B chips.
I have found that schematics with these 2 chips (see included file).
Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
Some measurements,... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by GentianI have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
- Loading...
