Y SUS for 42mf231d/37 magnvox plasma
  • fhorta
    • Oct 2010
    • 9
    i checked ebay to order the y sustain for tv. seems the ebay deal that plain bill posted is no longer being offered. i didnt get the chance to order due to cash flow restrictions. anybody know where else i can order the y sustain. thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: Y SUS for 42mf231d/37 magnvox plasma
    Search for the part number of the board. It appears alternate numbers are LJ41-03439A or a LJ92-01346A.
    I wish you had continued the previous thread. I hope I mentioned that the recommendation is to replace both Y buffers and the Y-Sustain at the same time. The usual failure sequence is a Y-buffer shorts, blowing the Y-sustain and possibly damaging the other Y buffer.
    PlainBill
    • troth530
      • Dec 2010
      fhorta,
      I found it as ebay item number: 160501740414.
      I too need some help if anyone can get me jump started (sorry to hijack your thread).
      I have the same TV with failed y-lower. The traces on the failed buffer were so bad I could not complete the repair, so have ordered a new board. I've done a lot of research on this and I've got an new lower y buffer on order, my upper y buffer seems to be checking out per the Coppell blog instructions, but not sure about ysus main. I could probably replace the IC and FETs and call it good on the y-sus, but now it seems my TV is exhibiting another symptom. Now when I get no sound, power. I need to check the main power supply board and am aware there are about 4 high voltages I need to check. Does anyone have any documentation on the main power board or know where I can obtain a manual for the 42mf231d/37. Or if you could just point me to where to check the voltages it would get me started.
      Thanks,
      Tim
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by troth530
        fhorta,
        Thanks,
        Tim
        This is tricky, so pay attention. First, go to http://english.electronica-pt.com/ and on the Model number to chassis page enter 42MF231D/37. That will then report the chassis number as TPE1.0U PA. Next, go to http://elektrotanya.com/ and enter TPE1.0U PA as the model number. That will bring up the proper service manual.
        The service manual gives very little information on the panel, buffers, power supply, etc because those were supplied by Samsung. Somewhere on the plasma panel you will find the SDI (Samsung Digital Imaging) part number. To cut this short, I believe this is the Samsung S42AX-XD02 panel. Again, search for that part number on Elektrotanya and you will get the service manual for the plasma panel.
        Checking voltages is easy. The output connectors on the power supply have the voltage designations labeled. There is a paper label on the plasma panel indicating the proper voltages for that panel.
        PlainBill
        • PlainBill
          • Feb 2009
          • 7034
          WARNING!!! Be very careful with the eBay auctions. The Y-Sustain listed in some auctions as for the 42MF231D/37 does NOT match the one in the TV I had. Check both the part numbers and the picture before ordering. The one in the auction listed above is correct.
          The picture in the service manual I referenced above does match the TV I had.
          Also, read the Coppell TV repair blog carefully. He emphatically suggests you replace both buffers and the Y-Sustain at the same time. My experience matches this.
          PlainBill
          • troth530
            • Dec 2010
            Re- replacing all boards per the blog...acknowledged. Thanks for the insight on getting manual and the basics of how to verify voltages, would not have figured that out myself.
            Tim
            • fhorta
              • Oct 2010
              • 9
              thanks for the response. fouond it again in ebay by item number. i was going to keep same thread but thought was a bit old and no one was looking into it anymore. my bad. i'm being charged $350 by tv repair man to just replace y main. asked if that is all that is wrong with it and he said yes. i'm more partial to plain bill however that boards should be replaced as well.
              good luck troth530. your in ggod hands with plain bill and company. seems you know alot more than i do anyway. thanks again. i will post results when i receive items.
              • retiredcaps
                • Apr 2010
                • 9271
                Newest flyers show that new name brand 42 inch plasmas are being sold for $499 CDN or less (with 1 or 2 year warranty).
                Name brand 50 inch 1080p plasmas are now $699 CDN. 50 inch 720p plasmas are at the $599 CDN level.
                So when paying $350 for a repair, just keep in mind what a new one costs.
                --- begin sig file ---
                --- end sig file ---
                • fhorta
                  • Oct 2010
                  • 9
                  okay, so the parts below are all compatible for this television? just heeding to warning. want to make sure i order the right part. i have yet to take part out of my tv so can't see part # on it. but just want to get an idea. the way i understand is there is more than one part # that can fit this tv?
                  thanks again.
                  LJ92-01200A / LJ41-02759A -part number on ebay
                  • PlainBill
                    • Feb 2009
                    • 7034
                    thanks again.
                    Replacement boards for plasma TVs are a real nightmare. Samsung uses two different part numbers. Philips (Magnavox) uses a third. A part number that begins with LJ41 is the part number for the bare pc board - no components. A part number that begins with LJ92 is the assembled circuit board. A manufacture such as Philips assigns a third number about 15 digits long which is their reference number. As a practical matter, either the LJ41 or LJ92 numbers can be used when searching for replacements.
                    LJ92-01346A is for the 42AX-YD02 panel, also called the W1 panel.
                    LJ92-01200A is the correct assembly for the 42AX-XD02 panel, also called the HD V4 panel
                    After checking pictures of both Y sustain board and their buffers, they are definitely not interchangeable. The LJ92-01346A has two wide and 1 narrow connectors to the buffers, the LJ92-01200A has two wide and two narrow.
                    PlainBill
                    • fhorta
                      • Oct 2010
                      • 9
                      just a quick update: extracted 3 boards. the y main does match part number of y main shown on ebay(pcb code-Lj41-02759a and pba code-Lj92-01200a). all boards say samsung on it.
                      did resistance tests on buffer boards and lower y board showed .12. the upper y board showed .2. i guess they need to be replaced per coppell resistance readings and results. just curious though about lower buffer board; per coppell, if board was bad, tv would not turn on. my tv always turned on, just no picture. would the .12 resistance still be enough to turn tv on? the way i understand it, reading of ohms' would need to be about 400 to 500 to indicate boards are good.
                      going to cost about $250 to $270 for both buffers and repaired/replaced y main, as plain bill had mentioned.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        There are several possible consequences of a failure of the Y-Sustain board. In some cases a fuse will blow and the TV will turn on. Other times the power supply will shut down due to detecting a fault condition (probably an overloaded supply).
                        One problem with replacing a Y-sustain board is there are several adjustments that must be made. One of then cannot be made without use of an oscilloscope.
                        PlainBill
                        • fhorta
                          • Oct 2010
                          • 9
                          thanks plainbill.
                          so when i get my replaced/repaired y main from coppell, it will not have the adjustments done to it already? or these adjustments must be done when parts are installed on tv? how much would it cost, ball park,to have adjustments done.can one do it himself? i undrstand an oscilloscope would be required. thanks again.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            thanks plainbill.
                            I have limited experience with this, but believe the TV may work if the adjustment is not done, but the panel life would be degraded. I have no idea how much it would cost to have someone else do it. The actual adjustment is easy, it's setting up to do it that is a pain. And just any scope won't do, you need a 200 Mhz scope.
                            Here's the link for the service manual for the panel. The picture of the panel is on page 12, the adjustment instructions are on page 64.
                            PlainBill
                            • fhorta
                              • Oct 2010
                              • 9
                              will take a look at manual. thanks .
                              • CoppellTVRepair
                                • Dec 2010
                                • 39
                                thanks plainbill.
                                That's a good question , but it will be better directed at Coppell TV Repair, don't you think? :-)
                                Your board will be adjusted, of course, for the display model that we have here.
                                There are different display models that require different board adjustments and the truth is we do not have every possible combination out there.
                                There's an important note I'd like to point: a lot of people seem to refer to our blog disscussing how to test for a short buffer, but do not seem to realize the updated article on the trio, which is more advanced and also more conclusive.
                                The most important thing to remember is that a buffer that does NOT show a short is still not guaranteed to be good! In fact, if it;s been working alongside with one that has shorted, it is equally bad.
                                I won't repeat everything from that second post here, only reiterate the conclusion: IF ONE OF THE BUFFERS GOES BAD YOU BETTER REPLACE BOTH!
                                Finally, the price considerations mentioned above are completely in-line with my own thinking. I bet Samsung is making much more money from service parts than from the original TVs (even though they were quite expensive at the time)!
                                • Keshenatech1
                                  LG 50PJ350 plasma blowing Y-Sustain board
                                  by Keshenatech1
                                  Hi, I was wondering if there's anyone here with experience on the LG50PJ350 plasma or similar models? When it came in, it had 7 shorted mosfet outputs on the Y-sustain board, Q02, 04,11, 22, 24, 26, and 28 were all dead shorted. I replaced them with the exact same type, checked their surrounding area for other open and shorted components and didn't see any further problems. But as soon as I hit the power button on the remote, I had a loud Pop! and Q22, 24, 26, and 28 are shorted out again. The other 3 seem to have survived. Someone on another forum had suggested the possibility of a shorted panel....
                                  05-13-2020, 10:08 AM
                                • ArMaaN376
                                  Samsung PS51E550 Plasma TV
                                  by ArMaaN376
                                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                  Opened TV cover & observed foll
                                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                  How to confirm Y -Buffer board...
                                  06-19-2024, 04:05 AM
                                • jm1234
                                  Panasonic plasma TX-P42ST50 - 6 blinks
                                  by jm1234
                                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                  I checked that board for any obvious faults...
                                  05-22-2024, 06:59 AM
                                • chazh
                                  LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                  by chazh
                                  This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                  I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                  The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                  09-01-2025, 08:56 PM
                                • porfyriadhs
                                  Samsung Plasma PS51D6900DS Bootloop
                                  by porfyriadhs
                                  Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                  Thanks a lot !!
                                  10-19-2023, 11:31 AM
