Vizio E550i-A0 no power, no standby light
+ More Options
Posts
  • lotas
    • Jan 2016
    • 4741
    • Russia
    Originally posted by x_orange90_x
    I'm still not sure if I'm seeing the website correctly. Still no replies here.
    If you can see this, please send me a direct message so I'll know.
    Yes, after changing the interface, the latest messages were not saved and were deleted.
    • x_orange90_x
      • May 2015
      • 727
      Ok great! Thanks for letting me know that. Anyway, I checked everything that RJ suggested and it all checked good. At first the diode checked bad, but after desoldering a leg it checked good. I haven't been sure where to look since. I'm starting to suspect this board is okay and the main is the culprit. Anything else I should check?
      • bunting78
        Vizio D650i-B2 wont trun on and no standby light
        by bunting78
        First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
        09-23-2021, 08:53 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • brithepi2k
        Sony KD-65XE8596 no standby light
        by brithepi2k
        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
        cheers...
        09-06-2025, 02:22 PM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
