Sanyo DP50747 50" / LG PDP50x4 T000 Panel Tv won't show video
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sanyo DP50747 50" / LG PDP50x4 T000 Panel Tv won't show video
    Originally posted by phatcav
    Am I supposed to short the pins on the cable connector or the board connector? I'm thinking the board connect since PIN1 on the cable is not utilized - PIN1 is the first pin on the lower left hand side of the cable and pin 2 is the pin right above it on the top row and it is pinned. I just want to make sure before i start jumping them. Thanks so much for the help up to this point btw.
    Thanks,
    phatcav
    If pin 1 of the cable is blank, you will have to short pins 1 & 2 on the main logic card.
    PlainBill
    • phatcav
      • Jan 2011
      • 10
      Well I got the main board ordered and it should be here by next Wednesday - i'll update and let everyone know if it corrected my issue. Thanks for everyones help.
      Thanks,
      phatcav
      • JBOliver09
        • Feb 2011
        Does anyone know what are the capacitors for this model, I have the sanyo with lg parts and was wondering if anyone knew, thanks!!
        • hijodalgo
          • Jan 2011
          • 35
          if it is an lg board you shoul dissconect the lvds cable and short the "AUTOGEN" testpoints in the control board, that will run a test like PlainBill said..usually the're very close to each other...
          • phatcav
            • Jan 2011
            • 10
            ok main AV board came in and that did not resolve my issue- so back to th edrawing boards - I checked the voltages again - only discrepancy is on a connector where the voltage should be 200-210 volts I get 195volts - could this be the issue? I see the panel is charged (very dimly lit) and have sound just no video....what to check next - i will also try the self test - this is a sanyo version of the tv...
            any suggestions would be greatly appreciated.
            thanks,
            michael
            • PlainBill
              • Feb 2009
              • 7034
              thanks,
              michael
              A very dimly lit panel usually indicates a bad Z-Sustain. What results did you get when you put the panel in test mode?
              PlainBill
              • phatcav
                • Jan 2011
                • 10
                #27
                well i have the samsung part # LJ41-05309A and when I short pin 1 and 2 on the logic board the screen goes from being dim to totally dark. I dont know if this is the self test on the samsung board?
                thanks,
                michael
                • phatcav
                  • Jan 2011
                  • 10
                  #28
                  Also - I see a Y-sus and X-main but I dont see a z-sus board?
                  thanks,
                  michael
                  • PlainBill
                    • Feb 2009
                    • 7034
                    thanks,
                    michael
                    As you are standing behind the TV, the Y-Sustain is on your left. The board in roughly the same position on the right is referred to as the X-main by Samsung, as the Z-sustain (Z-sus) by LG Electronics.
                    PlainBill
                    • phatcav
                      • Jan 2011
                      • 10
                      #30
                      Thanks Bill - i was wondering if it was another term for one of the other boards.
                      Thanks,
                      michael
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Thanks,
                        michael
                        Terminology is always a problem with plasma TVs. Each company that makes plasma panels and each company that makes plasma TVs have adopted their own terminology. Samsung is perhaps the worst. As I recall, they have about 4 'main' boards in their plasmaTVs. There's an x main board, a y-main board, a logic main board, and a miscellaneous main board. Philips uses Samsung panels, but uses their own terminology.
                        PlainBill
                        • madmike56
                          • Jun 2011
                          • 5
                          #32
                          these are the pics of the tv and the board that just clicks twice when powered up. no other sound or pic.
                          Please help
                          thanks
                          mike in tucson
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Please help
                            thanks
                            mike in tucson
                            For a number of reasons, I won't open pictures stored offsite. Attach the pictures to your next post using 'Manage Attachments' below the text entry area.
                            PlainBill
                            • tonyspark
                              • Jul 2011
                              #34
                              I have the exact same problem as everyone else here. Same model Sanyo DP50747(Panel LG PDP 50X4####). Plasma turns on and stays on. D2 and D5 are off. D3 and D4 are on. Screen is bright, with no defects. My problem is that I get no video or sound, and none of the menu buttons work. When you press the menu buttons on the TV, it does not even respond. Even pressing the power button does nothing. When plugging in the AC cable. The plasma automatically turns itself on. After that I get nothing. Only way I can get the TV to turn off is by unplugging it. I bought this tv broken and thought that I would fix it. When I originally opened their were about 8 bad caps PSB, also the fuse was missing from the power supply. I bought new ones of the exact same and replaced them. That was only a couple of days ago and I can already see them going bad! I also expect that their is a wire missing that goes from the power supply to the main board, but I'm not 100% sure(Their is no wiring diagram that I could find). Low hum coming from Y and Z Boards. I'm pretty sure their good cause screen shoudn't ven turn on if they weren't. I think I have it down to either the PSB or Main Board need to be replaced, but i'm not sure wich one tho. Or it could just be a missing wire that goes from the PSB to the main Board. Will be post pics of the unit up later today. Please help ASAP! Greatly Appreciated
                              • PlasMatt
                                LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                by PlasMatt
                                I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                09-20-2025, 06:50 PM
                              • DynaxSC
                                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                by DynaxSC
                                Hi
                                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                08-04-2025, 12:20 PM
                              • legg
                                LG 42PC3 buffer output doesn't follow YSUS
                                by legg
                                LG42PC3D -UD originally with green lamp but no display or audio.
                                Owner says was working, then went 'pop'.
                                All 5V caps bulging. replaced.
                                All PSU output voltages within spec but -Vy is low on YSUS.
                                One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                eventually shorts DG. Replaced all 3 - -Vy now OK.
                                Y scan buffer test point does not follow YSUS output below -50V
                                Note: This unit seems to expect YSUS output to park at -Vy in between
                                drive signal pattern periods. A replacement drive signal board confirms this....
                                11-18-2021, 11:49 AM
                              • Kemer
                                Led status indicator light transfer plastic
                                by Kemer
                                Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
                                There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
                                The plastic piece doesn't appear to be broken.
                                1. What are your suggestions for resolving this issue?
                                2. Is the plastic piece made of special ma...
                                08-19-2025, 07:02 PM
                              • MagicSmoke
                                Older Sanyo DP50747 VE Voltage High
                                by MagicSmoke
                                Working on an old Sanyo 50" that has Samsung innards. Backstory.. saved from dumpster years ago, partial recap on SMPS, Replaced one of two small caps on X-main, set worked great for about 3 years.
                                Then recently it started to take a few minutes from power on to display a pic and sound, worked like that for about 3 months, then Smps would click once and then nothing, it will not shut itself off but nothing happens.
                                So pulled PS replaced all the caps, even the large mains. PS works and has all stable rated voltages present when switched on. TV has sound (static) when...
                                12-02-2020, 11:56 PM
