Swisstec T42/1SG PSU Problem
  • stephenjames
    • Feb 2009
    • 14
    • England
    Hi Every one
    I have a dead swisstec and have discovered that the viper22A is defunct.I have a new ic but what i need to know is the value of zener diode ZD101 which is next to this chip and is short circuit.The psu board is made by samsung and the number is LJ4400092C.Can anybody help?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Swisstec T42/1SG PSU Problem
    datasheet.
    https://cdn.badcaps-static.com/pdfs/...63a52173ac.pdf
    often the reference circut will get you there.any markings on it?
    how is it connected?
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • SDNarcia
      Dell 15R-5521 keyboard problem (KBC?)
      by SDNarcia
      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
      As additional information,...
      07-20-2024, 10:47 PM
