TCL 65s423
    TCL 65s423
    Question, I know Its the backlight. I know how to replace one led but sometimes it comes up slightly brighter then the other. I have tried this on another TV and worked but ....
    Can I just take the LED off that is bad and just solder the connection together without putting a light there. When I did this on a donation TV it worked and wouldn't show any difference in quality. Although the voltage going to the lights was 3v less with LED tester and will be 3 v higher when turned on. Will this cause a problem quickly?? Thanks
    Re: TCL 65s423
    Just one should be ok, using a funai with that repair daily for last 2 years.
      Re: TCL 65s423
      What's a funai, and what if it was 2? Lol
        Re: TCL 65s423
        It's a tv, I think japan owns the company, they are prolly made in china, I don't know 2 might be pushing it, I thought I saw someone maybe on youtube that did more than 1 that may have used an added resistor to keep things balanced but it's been quite a while since I saw it.
          Re: TCL 65s423
          I don’t think one is brighter. I think it’s the color temp. of the led.
          Just replace the single led. Order a few different 3v and 6v leds with different color temp. Ie; warm white, cool white and even some cold white. There not expensive and if your fixing TVs here in there you will need them later.
            Re: TCL 65s423
            I think this isn't best think .in my opinion the you will bwill be better to replace the hole line with new one to prevent returning back
              Re: TCL 65s423
              We always recommend replacing the all the strips but sometimes it's not feasible or people just want to be cheap.
              That being said I have replaced single led on Hisense and tcl because they're cheap TVs and if you turn the backlights down they usually last a year or more
