sony kdl-40w650d No picture
  • j0gigs
    • Dec 2012
    • 56
    I have a sony kdl-40w650d that has sound and backlight but no picture. I had the same issue 2 years ago and replaced the main board and that fixed the problem. I do not want to invest another $70 in this tv to replace it again and was hoping someone may know what the problem is as this seems to be a common issue with this tv. Any help is greatly appreciated.
  • nomoresonys
    • 12332
    • U.S.
    Re: sony kdl-40w650d No picture
    Check if you have about 12 volts dc on each side of the tcon fuse, neg. probe on chassis ground.
    • CyberPhoenix
      Issue with picture quality of Sony bravia TV
      by CyberPhoenix
      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
      01-22-2024, 02:08 AM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • ronni
      Sony KD-43XE8005 with sound, backlight, no picture
      by ronni
      I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
      When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
      Removing the LVDS cable results in...
      12-01-2022, 08:44 AM
    • GraphicMan
      sony sdm-p234 very rare issue never seen before
      by GraphicMan
      The monitor is old yes but occasionally used (perhaps about 1 ~2 hours usage per day on average)
      one time i turned the pc on and noticed this issue
      what could it be?
      nothing wrong is seen when it is off, also the issue is not there on a green screen!
      when watching movies it is hard to detect unless in black screen/large shadows
      please check the images, thanks...
      04-14-2024, 10:06 AM
