Samsung QE50Q67T bootloop problem
  • Roccolade
    • Feb 2023
    • 8
    • Denmark
    Hey everyone.
    I have a Samsung QE50Q67TAUXXC (same as Q60T i think) which is experiencing constant bootloop. The picture comes on at first but then it begins to reboot again and again. I tried taping off the pins one by one on the ribbon-cable connecting the two panels at the bottom - and found that the bootloop stops when 1st pin from the left is taped off and the same if the 46th is taped off. (See picture). But unfortunately, I get no image on the screen in those cases.
    The bootloop also stops when the whole right side is disconnected. Which makes me believe the problem might originate here. (see picture).
    Does anyone have any idea what the problem might be? And what my next move could be?
    Thank you in advance
  • Donny2derby
    • Apr 2023
    • 228
    • Uk
    Re: Samsung QE50Q67T bootloop problem
    Trace the pins which give you the effect of stopping boot loop and see what they connect to!
    • Roccolade
      • Feb 2023
      • 8
      • Denmark
      Do you think its possible to find any kind of schematics of the boards? I haven't had any luck myself.
      • lotas
        • Jan 2016
        • 4600
        • Russia
        Try to mask these contacts here.
        • Roccolade
          • Feb 2023
          • 8
          • Denmark
          It still loops and there are a lot of horizontal lines on the screen.
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            something is likely getting hot .. check with thermal camera or similar device or you bare finger .
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4330
              • Italy - Milan
              check diodes, capacitors, big resistors on the panel stripe boards for short/open
              • Roccolade
                • Feb 2023
                • 8
                • Denmark
                I've tried checking for hot components, but nothing seems to heat up. I will try going through all the component to see if anything is faulty.
                About the two contact pins that can stop the bootloop when taped off. I seems to be FB_1 and FB_2 but i'm no completely sure what that tells me. I can find very little information about these board.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4330
                  • Italy - Milan
                  Them could be similar to trdy_1, trdy_3, a ready state loop signal free from tension..
                  • Roccolade
                    • Feb 2023
                    • 8
                    • Denmark
                    And what does that tell me?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4330
                      • Italy - Milan
                      fb could be feed back, probably a closed loop means problems on the panel
                      • Roccolade
                        • Feb 2023
                        • 8
                        • Denmark
                        For some reason the tv started to not show a picture at all. It simply started the bootloop right away. Even with the before-mentioned pins taped off. I managed to stop the loop again by taping of a pin on the ribbon cable going into the main board. Pin 30 from the bottom. Any ideas? Or is it even fixable?
                        • Storyteller12
                          • Jun 2020
                          • 624
                          Short answer is no, it’s not fixable. Even when they do work with the tape method assuming it is a bad panel all the ones I see have some type of degraded picture. Some have faint lines, some have certain colors slightly off and others just simply can’t be fixed.
                          It’s never a perfect picture again.
                          • sordids999
                            • May 2013
                            • 2152
                            Hi does anyone know what component this is ?
                            one is showing open on diode mode
                            Tv in bootloop no picture
                            • lotas
                              • Jan 2016
                              • 4600
                              • Russia
                              Resistors whose resistance is not known (there is no marking) may show 0 Om (plays the role of a jumper).
                              • viking6791
                                • Aug 2018
                                • 42
                                • My Desk
                                The panel has problems, in some cases I managed to make it work (the devices have been working for two months without problems), but it is not a long-term solution. Read the attached link where the given solution is for bootloop https://www.badcaps.net/forum/troubl...ines-on-screen
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  Samsung UN55JU650DF network/streaming problem
                                  by howardc64
                                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                  07-09-2025, 12:44 PM
                                • fanaticgames
                                  Samsung UE50TU8070UXZT bootloop display problem
                                  by fanaticgames
                                  Hi guys I have a problem with this TV, once it is turned on it restarts continuously (only the backlight is present, no image), by disconnecting the flat of the display it remains on regularly, can I solve it with scotch tape? What slopes of the flat can I cover?...
                                  04-27-2023, 12:49 PM
                                  09-06-2024, 11:40 PM
