samsung ue46c8000 problem with standby
  • Wolf1977
    • Jul 2023
    • 59
    • Greece
    hi to all
    i downloaded the service manual of power supply
    and because it has burnt the ic iCE3BR1765J and the fuse 2 ampere and probably the transformer ic801s i wanted to test the rest circuit if it has not problem so i take a power supply and give 5volt dc to the points + on nr 1 of db803 and - on minus of capacitor cb856
    but when i give voltage the relay rl801s click on and off from the motherboard i suppose something missing or goings wrong
    i connect and the power supply plug on the tv 220volt and i have desolder the transformer
    can someone tell me if its possible to test the circuit with the way i have thought
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Re: samsung ue46c8000 problem with standby
    Few informations, how many ampere do you feed with 5v? i guess needs at least 2A to be sure, furthermore you must test the rest of the psb at bench giving the on signal (a diode between 5v and ps-on pin) and applying test loads
    • R_J
      • Jun 2012
      • 9623
      You can NOT test the power supply without the standby circuit working, look at the schematic, The standby circuit also supplies the IC_VCC2
      • Wolf1977
        • Jul 2023
        • 59
        • Greece
        for this reason i ask
        from your experience is there way to test it with this way ?
        i use power supply 5volt 5 ampere
        it passes 400 ma from the circuit when it arms the coil of relay and after goes out
        but this happen fron the mainboard something sees wrong and it happens
        from the philoshophy of schematic it seems it doesnt play rule the ic i have refer above something other reason happens and i cannot undersand
        yet
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4535
          • Italy - Milan
          i don't understand well your language, but R J that looked at schematic states that the main psb stage and probably the pfc needs the current by auxiliary winding of stby circuit to be operative, so put aside the external psu and repair the ps board, ice3br , and so on, if transformer bad , rewind it or buy an used board..
          • Wolf1977
            • Jul 2023
            • 59
            • Greece
            I understood
            i see and i the transformer plays very important rule
            i want to ask you something more just to be sure
            can i check if the transformer work without the ic ;
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4535
              • Italy - Milan
              needs a ring tester
              • R_J
                • Jun 2012
                • 9623
                It is unlikely to be the transformer, ICB801 pin 4,5 drives the transformer primary, The ic has an internal startup cell that supplies a small voltage (vcc pin 7) that will charge CB802 to start the ic switching operation. The feedback winding (RB805,DB804) will charge CB802 to a higher voltage (20v) to keep the ic operating.
                There is also another winding that supplies (RB809,DB806) that charges CB805 to about 20~25 volts. QB801 is a regulator/switch that supplies 15 volts to IC_VCC, (pfc icp801,icm802) QB801 is turned on by PC802S
                If the ic was bad, check that RB806 is not open. It is good practice to replace CB802 and CB805 as they are usually weak because the standby is always operating.
                • Wolf1977
                  • Jul 2023
                  • 59
                  • Greece
                  THANKS A LOT SIR FOR THE DETAILED DESCRIPTION OF THE OPERATION OF THE CIRCUIT
                  JUST BECAUSE IN MY CASE HAD BURNED THE RESISTANCE THE RESISTANCE
                  RB809 2,2OHM 2 WATT AND THE FUSE FB801S 2A AND ACCORDINGLY BELLOW VIDEO MUST I CHANGE THE IC AND THE TRANSFORMER
                  https://www.youtube.com/watch?v=vvWwinflWYI
                  SO IN YOUR OPINION THERE IS NOT CASE TO HAVE SOMETHING THE TRANSFORMER
                  I WILL ORDER ONLY THE IC CE3BR1765J ICB801 AND THE DAMAGED COMPONENTS AND THE CAPACITORS THAT YOU SUGGEST ME TO SEE IF I REOAIR THE TV
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4535
                    • Italy - Milan
                    You cannot know if a trasformer is bad watching a video, you mustreplace the other components testing them with the lamp.in series trick
                    • nomoresonys
                      • 12328
                      • U.S.
                      I agree, usually most everything else will go bad before the transformer.
                      • Wolf1977
                        • Jul 2023
                        • 59
                        • Greece
                        Excuse me what is the trick of lamp in
                        is there someone education video that it shows the way ?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4535
                          • Italy - Milan
                          You desolder the main fuse and solder a lamp holder with wires plus halogen lamp, if the tv draws 100w then you can put a 100w lamp if i remember, this to avoid burning the new components , if lamp glows and stays on then a short is still present
                          • Wolf1977
                            • Jul 2023
                            • 59
                            • Greece
                            so just to be sure in my case
                            i will solde in series with the fuse S801S
                            6.3A a lamp 100 watt and i test it when i change the components first
                            while if its all right the lamp will not light bright
                            • nomoresonys
                              • 12328
                              • U.S.
                              Just build yourself a simple Series Lamp Limiter (Dim Bulb Tester) check youtube there's probably at least 50 how to videos there, if one video is confusing look at the next one, they are simple to make.
                              • Wolf1977
                                • Jul 2023
                                • 59
                                • Greece
                                ok sirs thanks a lot for your answers i will do it
                                just i wanted to be sure to protect the new components when i replace these
                                and for improve my knoledges on the electronics of cource
                                i like the fact that all of you agree the transformer will be ok
                                i hope you have right
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4535
                                  • Italy - Milan
                                  i don't agree, i have not seen your link, the transformer can go bad but is almost rare
                                  • Wolf1977
                                    • Jul 2023
                                    • 59
                                    • Greece
                                    ΘΑ ΗΘΕΛΑ ΝΑ ΡΩΤΗΣΩ ΑΝ ΓΝΩΡΙΖΕΙ ΚΑΠΟΙΟς Ο ΜΕΤΑΣΧΗΜΑΤΙΣΤΗς STANDBY
                                    ΤΟΥ ΤΡΟΦΟΔΟΤΙΚΟΥ BN44-00362a και του τροφοδοτικου BN44-00363a ειναι ιδιοι;
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4535
                                      • Italy - Milan
                                      Ancient Greece, Zeus... Apollo.. Eros.. ???
                                      • Wolf1977
                                        • Jul 2023
                                        • 59
                                        • Greece
                                        σωστα αλλα δεν μου απαντησατε κυριε
                                          09-07-2024, 05:50 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
