  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4556
    • Italy - Milan
    Re: SAMSUNG UN55KS9000F picture fades then distorts into vertical lines after 20 seco
    No, the caps are brown
    • JJAAMM
      • Jul 2023
      • 16
      Yeah- that's what I thought. None of them are shorted. Though two of them have no continuity to ground.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4556
        • Italy - Milan
        the two are normal
        • JJAAMM
          • Jul 2023
          • 16
          the two are normal
          There has to be something I'm missing here. It's driving me nuts.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4556
            • Italy - Milan
            No much misteries, caps can go short after a bit of warming up, the hard thing is to make the faulty cap reveal the short under test, you can strongly heat all them with hair dryer then check again for shorts
            • JJAAMM
              • Jul 2023
              • 16
              OK I’ll try that
              • noisykid
                Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                by noisykid
                5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                12-30-2024, 07:15 PM
              • Stanley1843
                Screen Display Vertical Multicolor Lines
                by Stanley1843
                Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                06-29-2024, 11:54 AM
              • hendue
                BenQ 2765HT vertical lines, no picture
                by hendue
                I was trying to fix the monitor, which was giving me the following pictures:
                It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                I turned around...
                09-09-2025, 08:27 AM
              • srs
                Insignia NS-50DR620NA18 w/ large vertical lines & no picture
                by srs
                I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
                A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
                I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
                04-22-2023, 02:40 PM
              • Falki
                Colorful LCD Vertical Lines on Samsung ue55es8090
                by Falki
                Hello there, ive recently found an older 55inch Samsung SmartTV.
                Sadly it has vertical lines at the left and one line in the middle-right.
                I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                I have factory resetted the TV as well but also with no luck.
                I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                A similar issue has been posted as well but also with no actual response ...
                08-12-2025, 04:19 AM
