Panasonic Plasma TH46PZ85U tuner problems
  • bluto
    • Oct 2007
    • 560
    My folks have a 46" Panasonic Viera Plasma TV. It is slightly more than 18 months old. They have only expanded basic analog cable + clear QAM channels playing through the internal tuner. The problem is that recently about half a dozen channels (no particular order here) have decided to not play any sound. It is always the same channels and yes I did check the other TVs in the house and the problem is not with the cable feed. I was told that once the turner also 'went crazy' and was continually scanning through all the channels without stopping. Apparently a power cycle cleared that up and I have not been able to get it to repeat that.
    I haven't taken apart yet. I am hoping that it is some bad caps
    Has anyone ever heard of this? I did some googling and found some references to tuner problems on panasonic plasmas, but nothing for this model. There was a post over at AVS that talked about upgrading firmwares, gave a link to a site, but that site is now password protected.
    It seems that even a good brand like Panasonic is not worth much for quality these days. I would expect these kind of problems on a wal*mart special after 18 months, but this was hardly such.
  • bluto
    • Oct 2007
    • 560
    Re: Panasonic Plasma TH46PZ85U tuner problems
    I found the part number of the main board to which the tuner is attached (TNPH0721ASS). Looks like an expensive part. The tuner module (ENGE6608KF) is available separately for ~$50. Would replacing the tuner module on the main board solve the problem with the set? Any tips?
    Also saw this: www-tiptoptuner-com (they were keyword bombing google with tuner part numbers). They promise to fix any tuner for $27. Anyone ever used them?
    • bluto
      • Oct 2007
      • 560
      I just got a chance to examine the TV. Channels 6, 28, 29, 32, 49 & 95 have no audio. So no obvious pattern there. The cable system there has analog channels up to 78 (with a few gaps in between) and 95 & 96 in the funky FM band of channels.
      I took a frequency chart (http://www.jneuhaus.com/fccindex/cablech.html), made it into a spreadsheet and highlighted the channels that are out. No obvious patterns there except the relationship between ch. 6 & 95 on the spectrum.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Odd. So you didnt find any bad caps?
        • bluto
          • Oct 2007
          • 560
          Have not had the time to take it apart yet.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Then how did you mske a picture of the board?
            • bluto
              • Oct 2007
              • 560
              I came up with the picture from a site selling the main board. Found that based on the model number. At some point I am going to open this thing up to see what is going on. But being a Panasonic, one could assume that it should have Panasonic caps in it. I guess there is only one way to find out for sure.
              • bluto
                • Oct 2007
                • 560
                Well I finally decided to tackle this one. I got a replacement tuner module for around $50. To make a long story short, I soldered it in there and the problem with some channels not having sound remained.
                So in the normal course of fiddling around, I came across the 'reset' menu. Had to give it a password (don't remember setting one), so I tried 1234 and amazingly that worked. After completing the reset and re-scanning channels, I was amazed to find that the previously soundless channels now had sound. So I solved the problem, but wasted $50 on an unnecessary tuner replacement. If anyone needs an ENGE6608KF tuner module, PM me and I will sell it cheap.
                Final thoughts: This was the first plasma that I have ever cracked open (have done lots of LCDs). I was almost dumbfounded with all the circuit boards inside, especially those having to do with the HV stuff driving the panel. I was also impressed with the build quality of the Panasonic. There was a lot of detail paid to everything all the way down to the cable tie down clips. Didn't see any Panasonic caps (not eating your own dog food) but lots of Rubycon and Chemicon (no cheapo teapo).
                In the end I am a little frustrated with the software bugs in this unit. This tuner problem was one of them. And it also has an issue of having multiple instances of a given clear QAM channel after the cable co shuffles them around (they frequently do). The old channel, now a 'ghost' channel, cannot be deleted. The factory reset took care of them, but that shouldn't be necessary to delete a channel. Is there any way to possibly obtain a firmware update? Although that is probably a long shot since manufacturers usually don't fix bugs on the old model unless it is severe enough to get lots of customers pissed off.
                • PlainBill
                  • Feb 2009
                  • 7034
                  You could try the Panasonic TV support website. I do know Philips makes firmware updates available and has a relatively simple process for installing them.
                  PlainBill
                  • bluto
                    • Oct 2007
                    • 560
                    Good idea. I googled the relevant terms and found this:
                    http://www.panasonic.com/announce/up...tv/service.asp
                    Only three models listed though. I guess those firmwares were really borked in version 1.0. It mentions loading them from an SD card. That would be nice.
                    The AVS post from 2006 that I was referring too at the top of this thread:
                    http://www.avsforum.com/avs-vb/archi.../t-750920.html
                    It mentions a site to get firmware (http://www.pasctraining.panasonic.co...downloads1.asp). But it is apparently now password protected.
                    Any idea on how to obtain the goods? Or just to know if updated goods are available for this model? A search on the forum revealed no other references to 'panasonic' and 'firmware' except this thread.
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      I happened several times, in the search for help from the web, to consult this very interesting forum.
                      So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                      Having said that I come to the gist of my post on the forum as the title suggests.
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
                    • Lintesir
                      Panasonic P42S30 Plasma - Pink sparkles
                      by Lintesir
                      My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                      There is about a 5cm high region at the top without any sparkles,...
                      07-26-2024, 03:16 AM
